AB2734B-LW100-R
AB2734B-LW100-R
    PUIAUDIO
    PIEZO CERAMIC BENDER 30V 1000OHM
AB2734B-LW100-R 数据手册
SPECIFICATIONS PARAMETERS RESONANT FREQUENCY RESONANT IMPEDANCE (MAX) MAX INPUT VOLTAGE CAPACITANCE @ 120 HZ PLATE MATERIAL OPERATING TEMPERATURE STORAGE TEMPERATURE VALUES 3,400 500 1,000 30 13,000 30% BRASS -20 ~ +60 -20 ~ +70 UNITS Hz Ohm Vp-p pF C C THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A RELEASED FROM ENGINEERING REVISED CAPACITANCE FREQUENCY 5/8/2013 2/12/2020 M.V. 2003, Projects Unlimited Inc. A 27 0.53 0.3 0.1 100 0.1 0.05 5 5 RED (+) 1 BLACK (-) UL1571 AWG #30 14.6 A ( 12 : 1 ) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AB2734B-LW100-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 5/8/2013 C.W. 5/9/2013 B.R. 5/9/2013 5/8/2013 AB2734B-LW100-R Bender Edition Sheet - 1/1
AB2734B-LW100-R 价格&库存
很抱歉,暂时无法提供与“AB2734B-LW100-R”相匹配的价格&库存,您可以联系我们找货
