AB1070B
AB1070B
    PUIAUDIO
    BUZZER ELEMENT PIEZO 7KHZ 10MM
AB1070B 数据手册
SPECIFICATIONS PARAMETERS RESONANT FREQUENCY RESONANT IMPEDANCE (MAX) MAX INPUT VOLTAGE CAPACITANCE @ 1kHZ PLATE MATERIAL OPERATING TEMPERATURE STORAGE TEMPERATURE VALUES UNITS 7,000 600 1,000 15 10,000 30% BRASS -20 ~ +80 -20 ~ +80 Hz Ohm Vp-p pF C C THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E F RELEASED FROM ENGINEERING REVISED RESONANT FREQUENCY TOLERANCE REVISED CERAMIC DIAMETER REVISED CERAMIC TOLERANCE REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED CERAMIC DIAMETER REVISED OPERATING AND STORAGE TEMPERATURE 9/7/2004 3/19/2007 1/16/2008 3/19/2009 8/9/2010 9/29/2016 1/3/2020 R.W. B.R. B.R. B.R. M.V. M.V. 2003, Projects Unlimited Inc. A 9.9 7.5 0.1 0.4 0.05 0.02 0.12 0.05 A ( 30 : 1 ) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AB1070B.idw Designed by Date R.A.C. 8/31/2004 Checked by Date Approved by Date Drawn Date R.W. 9/7/2004 8/9/2010 AB1070B Bender Edition Sheet - 1/1
AB1070B 价格&库存
很抱歉,暂时无法提供与“AB1070B”相匹配的价格&库存,您可以联系我们找货
AB1070B
    库存:293
