AB4141B
AB4141B
    PUIAUDIO
    BUZZER ELEMENT PIEZO 4.1KHZ 41MM
AB4141B 数据手册
SPECIFICATIONS PARAMETERS RESONANT FREQUENCY RESONANT IMPEDANCE (MAX) MAX INPUT VOLTAGE CAPACITANCE @ 100 HZ PLATE MATERIAL OPERATING TEMPERATURE STORAGE TEMPERATURE VALUES 4,100 500 1,000 60 100,000 30% BRASS -20 ~ +60 -20 ~ +70 UNITS Hz Ohm Vp-p pF C C THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED INPUT VOLTAGE, OVERALL THICKNESS REVISED CAPACITANCE FREQUENCY 4/20/2006 8/26/2010 3/31/2015 2/14/2020 B.R. M.L. M.V. 2003, Projects Unlimited Inc. A 41 0.2 25 0.4 0.2 0.02 0.31 0.05 A ( 11 : 1 ) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AB4141B.idw Designed by Date Checked by Date Approved by B.R. 4/20/2006 B.R. 4/21/2006 E.P. Date Drawn Date 4/21/2006 8/26/2010 AB4141B Bender Edition Sheet - 1/1
AB4141B 价格&库存
很抱歉,暂时无法提供与“AB4141B”相匹配的价格&库存,您可以联系我们找货
