SPECIFICATIONS
PARAMETERS
RATED VOLTAGE (SQUARE WAVE)
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
COIL RESISTANCE
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNITS
5
3~7
40
47 7
87
2,400 500
-30 ~ +80
-40 ~ +85
PBT
Sn PLATED
BRASS
2
V0-p
V0-p
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PUI AUDIO, INC. ANY USE OR REPRODUCTION, IN
ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION
OF PUI AUDIO, INC. IS PROHIBITED.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
RELEASED FROM ENGINEERING
REVISED OPERATING TEMPERATURE
CHANGED VOLTAGE RATINGS FROM Vp-p TO V0-p
7/24/2014
11/26/2018
1/15/2019
M.L.
M.V.
2010, PUI AUDIO Inc.
mA
OHM
dBA
Hz
C
C
grams
REMOVABLE TAB
3.8
12
POTTING
0.3
6.5
2X 0.6
0.3
0.1
0.5
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2015/863/EU COMPLIANT.
9
0.3
UNLESS OTHERWISE SPECIFIED:
All PURCHASES ARE SUBJECT TO AND
INCORPORATE THE PUI AUDIO TERMS
AND CONDITIONS SALE FOUND AT
http://www.puiaudio.com
/pdf/terms_conditions.pdf
(paper copy available upon request).
DIMENSIONS ARE IN MILLIMETERS,
TOLERANCES ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
AT-1224-TWT-5V-2-R.idw
Designed by
Date
Checked by
Date
Approved by
J.D.
7/24/2014
C.W.
7/24/2014
R.W.
Date
Drawn Date
7/24/2014 7/24/2014
AT-1224-TWT-5V-2-R
Transducer (Electro-Mech)
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AT-1224-TWT-5V-2-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.488501+0.90294
- 10+5.5928610+0.67437
- 25+5.0160325+0.60482
- 50+4.6281950+0.55805
- 100+4.27728100+0.51574
- 300+3.78573300+0.45647
- 500+3.58109500+0.43180
- 1000+3.325041000+0.40092
- 5000+2.812645000+0.33914
- 国内价格
- 1+4.23740
- 50+3.64510
- 100+3.37760
- 500+2.99480
