Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
MODEL: CCG-1206 | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER
FEATURES
• through hole
• 5 V rated
• externally driven
SPECIFICATIONS
parameter
rated voltage
conditions/description
Vo-p
min
4.0
0V
at rated voltage, 2,400 Hz square wave, ½ duty
rated frequency
sound pressure level
at 10 cm (A-weight), rated voltage, 2,400 Hz square wave,
½ duty
coil resistance
dimensions
max
5.0
operating voltage
current consumption
typ
units
Vo-p
8.0
Vo-p
50
mA
2,400
Hz
85
91
dBA
36.0
42.0
48.0
Ø12.0 x 9.5
Ω
mm
weight
1.6
material
PBT+15% GF
terminal
pin type (Sn plating)
g
operating temperature
-35
75
°C
storage temperature
-40
85
°C
max
units
380
°C
265
°C
washable
yes
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
hand soldering
for maximum 2 seconds
330
wave soldering
see wave solder profile
255
Temperature [°C]
Soldering Pot:260±5°C
4°C/s max
Cooling by air
A=5s max
Pre-heating 160°C Max
4°C/s max
120s Max
Time [sec]
cuidevices.com
typ
260
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CCG-1206 | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
Laser Print
WEEK
01
02
YEAR
20---2020
21---2021
FREQUENCY RESPONSE CURVE
APPLICATION CIRCUIT
cuidevices.com
CCG-1206
CUI 0121
CHINA
Product Page
3D Model
PACKAGING
units: mm
Tray Size: 184 x 180 x 23 mm
Carton Box Size: 445 x 405 x 320 mm
Tray QTY: 100 pcs per box
Carton Box QTY: 6,000 pcs per carton
10x10=100PCS
7UD\
SFV7UD\
,QQHU%R[
3FV
&DUWRQ%R[
3FV,QQHU%R[
cuidevices.com
PCB Footprint
date 08/05/2022 | page 3 of 4
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
03/19/2007
1.01
brand update
02/04/2020
1.02
modified housing
09/15/2021
logo, datasheet style update
08/05/2022
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CCG-1206”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+4.18014500+0.49950
- 1000+4.087251000+0.48840
- 1500+4.068061500+0.48611
- 2000+4.040802000+0.48285
- 2500+3.947912500+0.47175
