AT-1220-TT-R
AT-1220-TT-R
    PUIAUDIO
    Peak-Peak Signal Buzzer Single Tone 2.048kHz Magnetic 1 ~ 3V 82dB @ 1.5V, 10cm
AT-1220-TT-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) COIL RESISTANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 1.5 1~3 15 42 6 85 2,048 500 -30 ~ +70 -40 ~ +85 NORYL Sn PLATED RED COPPER 2 V0-p V0-p THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PUI AUDIO, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PUI AUDIO, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REMOVED LEAD FREE ADDED RoHS NOTE REVISED MINIMUM SPL REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED RATED VOLTAGE AND VOLTAGE RANGE FROM VP-P TO V0-P REVISED RATED CURRENT, SPL, AND TEMPERATURES 9/2/2004 8/10/2005 11/29/2007 4/7/2008 R.W. B.R. 8/14/2017 M.V. 2/25/20 M.L. 2010, PUI AUDIO Inc. mA OHM dBA Hz C C - D E grams 5 12 0.2 8.5 0.2 2.3 0 SOUND EMISSION HOLE 6.5 0.6 0.2 0.1 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2015/863/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AT-1220-TT-R.idw Designed by Date R.A.C. 9/2/2004 Checked by Date Approved by Date Drawn Date R.W. 9/2/2004 4/7/2008 AT-1220-TT-R Transducer (Electro-Mech) Edition Sheet - 1/1
AT-1220-TT-R 价格&库存
很抱歉,暂时无法提供与“AT-1220-TT-R”相匹配的价格&库存,您可以联系我们找货
AT-1220-TT-R
    • 1+9.61200
    • 200+3.84480
    • 500+3.71520
    • 1000+3.65040
    AT-1220-TT-R
    • 1+12.394671+1.61072
    • 10+9.3434310+1.21421
    • 25+8.3981125+1.09136
    • 50+7.7610050+1.00857
    • 100+7.18230100+0.93336
    • 300+6.37092300+0.82792
    • 500+6.03264500+0.78396
    • 1000+5.608271000+0.72881
    • 5000+4.757455000+0.61825
    库存:25087
