CSS-I4B20-SMT-TR
CSS-I4B20-SMT-TR
    CUIDEVICES
    BUZZER MAGNETIC 3.6V 8.5MM SMD
CSS-I4B20-SMT-TR 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 08/05/2022 page 1 of 4 MODEL: CSS-I4B20-SMT-TR | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER FEATURES • large sound port • top sound port • externally driven SPECIFICATIONS parameter conditions/description Vo-p rated voltage min 3 0V at rated voltage, 2,730 Hz square wave, ½ duty rated frequency sound pressure level at 5 cm (A-weight), rated voltage, 2,730 Hz square wave, ½ duty coil resistance dimensions max 3.6 operating voltage current consumption typ units Vo-p 5 Vo-p 80 mA 2,730 Hz 85 90 dBA 17 20 23 8.5 x 8.5 x 3 Ω mm weight 0.6 material LCP (white) terminal SMT type (Au plating) g operating temperature -30 70 °C storage temperature -40 85 °C max units 30 °C 260 °C RoHS Notes: yes 1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted. SOLDERABILITY parameter conditions/description reel storage at relative humidity
CSS-I4B20-SMT-TR 价格&库存
很抱歉,暂时无法提供与“CSS-I4B20-SMT-TR”相匹配的价格&库存,您可以联系我们找货
