SC900CT
SC900CT
    SWITCHCRAFT
    INSTRUMENT DIRECT BOX
SC900CT 数据手册
8 7 6 5 4 3 2 1 NOTES: 1. ALL DIMENSIONS FOR REFERENCE ONLY. 2. MATERIALS: HOUSING, END, AND COMPONENT PANELS ARE BLACK ANODIZED ALUMINUM. 3. LASER ETCHED WHITE TEXT AND ARTWORK. 4. POWER REQUIREMENTS FOR PHANTOM LIFT FEATURE: 44-52 VOLTS (DC) PHANTOM POWER (P48) 5. THIS PRODUCT IS RoHS COMPLIANT F F CONTROLS: 4.16 105.7 INPUT: ¼” (6.3mm) MONO PHONE JACK. ACCEPTS SIGNALS FROM INSTRUMENTS. THRU: ¼” (6.3mm) MONO PHONE JACK. WIRED IN PARALLEL WITH INPUT. E E -20dB PAD: TOGGLE SWITCH. REDUCES INPUT SIGNAL LEVEL AN ADDITIONAL 20dB FOR LINE LEVEL SIGNALS. 3.35 85.1 INPUT MIC OUTPUT: 3 PIN MALE XLR. PROVIDES BALANCED, LOW IMPEDANCE MIC LEVEL OUTPUT. WIRED PIN-1 GROUND, PIN-2 HOT, PIN-3 COLD. MIC OUTPUT THRU GROUND LIFT MODE: RECESSED SLIDE SWITCH. USE TO SELECT WHICH FORM OF GROUND CONTROL TO USE. D MANUAL MODE - ENABLES CONTROL OF THE GROUND LIFT FROM THE DI USING THE TOGGLE SWITCH. 2.10 53.3 PAD 48V MODE - ENABLES REMOTE CONTROL OF THE GROUND LIFT FROM THE CONSOLE USING 48 VOLT PHANTOM POWER. LIFT/GND 0.04 1.1 C D LED GROUND LIFT MODE PHANTOM POWER OFF: XLR PIN-1 GROUNDED PHANTOM POWER ON: XLR PIN-1 LIFTED LIFT/GND: TOGGLE SWITCH. FUNCTIONAL ONLY WHEN IN MANUAL GROUND LIFT MODE. C LIFT PIN1: XLR PIN-1 LIFTED GND: XLR PIN-1 GROUNDED RUBBER STRIPS LED: ILLUMINATES BLUE (INDICATING XLR PIN-1 IS LIFTED) WHEN PHANTOM POWER IS ENGAGED. FUNCTIONAL ONLY WHEN IN 48V MODE. B B CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED B 27673 A 26785 REV ECO NUMBER 5-1-16 TO TJK 06-09-11 JEB TJK DATE REVISIONS 8 7 6 5 4 BY APVD WIDTH MULT FINISH 1. ALL DIMENSIONS IN INCHES A SIZE - TWO PLACE DECIMALS 0.02 - THREE PLACE DECIMALS 0.005 DO NOT SCALE DRAWING SolidWorks CAD File BY A SPEC No. SCALE CHKD 1:1 APVD TJK JEB 12-6-10 BHM 11-20-12 11-20-12 NAME INSTRUMENT DIRECT BOX WITH PHANTOM LIFT C TEMPER MATERIAL SPEC No. FIRST USED ON DATE DRAWN LBS/M SHEET PART No. 1 SC900CT OF 3 REV B 8 7 6 5 4 3 2 1 F F E E D D C C B B CUSTOMER DRAWING A A SCALE 1:1 DATE DRAWN 12-6-10 DRAWN BY SHEET PART No. BHM 8 7 6 5 4 3 SolidWorks CAD File C 2 SC900CT OF 3 REV B 8 7 6 5 3 -20dB PAD TOGGLE SWITCH 1/4" INPUT F 4 2 1 IMPEDANCE MATCHING TRANSFORMER, FULLY SHIELDED F 1/4" THRU XLR OUTPUT (LOW-Z) E E RF FILTER D D MANUAL MODE XLR PIN-1 GROUND LIFT TOGGLE SWITCH GROUND LIFT MODE SLIDE SWITCH MANUAL C C 48V PHANTOM LIFT CIRCUIT FOR 48V MODE XLR PIN-1 LIFTED FROM INPUT GROUND WHEN 48 VOLT PHANTOM POWER IS ENGAGED. B B LED ILLUMINATES WHEN LIFTED IN 48V MODE A PATENT PENDING CUSTOMER DRAWING A SCALE 1:1 DATE DRAWN 12-6-10 DRAWN BY SHEET PART No. BHM 8 7 6 5 4 3 SolidWorks CAD File C 3 SC900CT OF 3 REV B
SC900CT 价格&库存
很抱歉,暂时无法提供与“SC900CT”相匹配的价格&库存,您可以联系我们找货
