POW-1644L-LWC50-B-R
POW-1644L-LWC50-B-R
    PUIAUDIO
    MIC COND ANALOG OMNI -44DB
POW-1644L-LWC50-B-R 数据手册
SPECIFICATIONS PARAMETERS DIRECTIVITY SENSITIVTY STANDARD OPERATING VOLTAGE MAX OPERATING VOLTAGE CURRENT CONSUMPTION (MAX) IMPEDANCE SIGNAL TO NOISE RATIO (MIN.) OPERATING TEMPERATURE TERMINAL INTERNAL CAPACITOR VALUES UNITS OMNI -44 3 2 10 0.5 2.2 60 -20 ~ +70 LEAD WIRE 33 + 10 - THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. dB Vdc Vdc mA KOhm dB C pF REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D RELEASED FROM ENGINEERING REVISED OPERATING TEMPERATURE AND IP RATING REVISED TO INVENTOR 3-D DRAWING TEMPLATE ADDED PIN LOCATION REVISED DIMENSIONS AND INTERNAL CAPACITORS 10/10/2006 6/9/2008 9/4/2008 7/14/2010 2/14/2020 B.R. B.R. B.R. M.V. ASSEMBLY C-C ( 5 : 1 ) C C 6 0.1 WATERPROOF BARRIER MICROPHONE 50 2.6 0.1 1.8 0.1 BOOT 3 B BLACK PIN 2 TERM. 2 (-) 3.2 0.1 4.9 RED PIN 1 TERM. 1 (+) UL1571 AWG #30 1.6 7 0.2 0.2 0.1 0.1 B NOTES: 0.1 5.8 B-B ( 6 : 1 ) 0.1 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 4. MOLEX CONNECTOR P/N: 51021-0200 5. PART IS IP57 RATED. 6. ASSEMBLY IS WASHABLE WITH BOOT IN PLACE. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 POW-1644L-LWC50-B-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 10/10/2006 B.R. 10/11/2006 R.W. 10/11/2006 9/4/2008 POW-1644L-LWC50-B-R Microphone Edition Sheet - 1/1
POW-1644L-LWC50-B-R 价格&库存
很抱歉,暂时无法提供与“POW-1644L-LWC50-B-R”相匹配的价格&库存,您可以联系我们找货
POW-1644L-LWC50-B-R
    • 2+25.24835
    • 20+22.72300
    • 200+20.98909
    • 1000+19.46347
    • 2000+18.88029
    库存:44
    POW-1644L-LWC50-B-R
      • 1+17.15040
      • 200+6.64200
      • 500+6.40440
      • 1000+6.29640
