ANM-5254L-R
ANM-5254L-R
    PUIAUDIO
    MIC COND ANALOG NOISE CAN -54DB
ANM-5254L-R 数据手册
SPECIFICATIONS PARAMETERS DIRECTIVITY SENSITIVTY STANDARD OPERATING VOLTAGE MAX OPERATING VOLTAGE CURRENT CONSUMPTION (MAX) IMPEDANCE SIGNAL TO NOISE RATIO (MIN.) TERMINAL INTERNAL CAPACITOR VALUES UNITS NOISE CANCELING -54 4 dB 1.5 Vdc 10 Vdc 0.5 mA 680 0.5% Ohm 55 dB SOLDER PADS pF N/A THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. LTR DESCRIPTION DATE APPROVED A B C D RELEASED FROM ENGINEERING ADDED TERMINAL POLARITY REVISED IMPEDANCE REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED SIGNAL TO NOISE RATIO 1/30/2006 1/30/2007 6/11/10 8/31/2010 2/14/2020 R.W. B.R. B.R. M.V. 2003, Projects Unlimited Inc. 5.2 9.7 REVISION HISTORY 0.2 0.1 1.2 (6) TERM. 1 (+) TERM. 2 (-) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 ANM-5254L-R.idw Designed by Date Checked by Date Approved by J.A.F. 1/31/2006 E.P. 1/31/2006 B.R. Date Drawn Date 1/31/2006 8/31/2010 ANM-5254L-R Microphone Edition Sheet - 1/1
ANM-5254L-R 价格&库存
很抱歉,暂时无法提供与“ANM-5254L-R”相匹配的价格&库存,您可以联系我们找货
ANM-5254L-R
  • 1+13.939061+1.80560
  • 10+10.5657510+1.36864
  • 25+9.5037325+1.23107
  • 50+8.7859850+1.13810
  • 100+8.13596100+1.05389
  • 300+7.22197300+0.93550
  • 500+6.84072500+0.88612
  • 1000+6.362191000+0.82413
  • 5000+5.402235000+0.69978
库存:4175
