POW-2242L-C3310-B-R
POW-2242L-C3310-B-R
    PUIAUDIO
    Analog Microphone Electret Condenser 2V Omnidirectional (-42dB ±3dB) Solder Pads
POW-2242L-C3310-B-R 数据手册
SPECIFICATIONS PARAMETERS DIRECTIVITY SENSITIVTY STANDARD OPERATING VOLTAGE MAX OPERATING VOLTAGE CURRENT CONSUMPTION (MAX) IMPEDANCE SIGNAL TO NOISE RATIO (MIN.) TERMINAL INTERNAL CAPACITOR VALUES UNIT OMINI -42 3 2 10 0.5 2.2 60 SOLDER PADS 33&10 - THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. dB Vdc Vdc mA KOhm dB pF REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED IP RATING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED BOOT DIMENSIONS 10/25/2006 7/2/2008 10/22/2010 2/19/2020 B.R. B.R. M.V. ASSEMBLY B B B-B ( 7 : 1 ) MICROPHONE 6 0.1 2.2 0.2 3 BOOT 7.4 2.8 A 2.5 3.2 TERM 2 (-) 0.6 6.5 5.9 3 7.2 TERM 1 (+) NOTES: A A-A ( 9 : 1 ) 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 4. PART IS IP57 RATED. 5. ASSEMBLY IS WASHABLE WITH BOOT IN PLACE. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 POW-2242L-C3310-B-R.idw Designed by Date Checked by Date Approved by J.D. 10/25/2006 R.W. 10/25/2006 B.R. Date Drawn Date 10/25/2006 10/22/2010 POW-2242L-C3310-B-R Microphone Edition Sheet - 1/1
POW-2242L-C3310-B-R 价格&库存
很抱歉,暂时无法提供与“POW-2242L-C3310-B-R”相匹配的价格&库存,您可以联系我们找货
