POW-1644L-B-R
POW-1644L-B-R
    PUIAUDIO
    MIC COND ANALOG OMNI -44DB
POW-1644L-B-R 数据手册
SPECIFICATIONS PARAMETERS DIRECTIVITY SENSITIVTY STANDARD OPERATING VOLTAGE MAX OPERATING VOLTAGE CURRENT CONSUMPTION (MAX) IMPEDANCE SIGNAL TO NOISE RATIO (MIN.) TERMINAL INTERNAL CAPACITOR VALUES UNIT OMINI -44 3 2 10 0.5 2.2 60 SOLDER PADS N/A - THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. dB Vdc Vdc mA KOhm dB pF 6 LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED IP RATING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED POLARITY 2/12/2007 7/2/2008 10/22/2010 4/2/2018 B.R. B.R. M.V. ASSEMBLY B-B ( 7 : 1 ) B B MICROPHONE 1.6 REVISION HISTORY 2.6 BOOT 0.3 A 0.2 0.1 7 0.1 0.1 TERM 1 (-) 4.9 0.1 5.8 0.1 TERM 2 (+) 3.2 0.1 NOTES: A 1.8 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 4. PART IS IP57 RATED. 5. ASSEMBLY IS WASHABLE WITH BOOT IN PLACE. 0.1 A-A ( 9 : 1 ) UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 POW-1644L-B-R.idw Designed by Date Checked by Date Approved by J.D. 2/12/2007 D.F. 2/12/2007 R.W. Date Drawn Date 2/12/2007 10/22/2010 POW-1644L-B-R Microphone Edition Sheet - 1/1
POW-1644L-B-R 价格&库存
很抱歉,暂时无法提供与“POW-1644L-B-R”相匹配的价格&库存,您可以联系我们找货
POW-1644L-B-R
    • 1+27.75600
    • 200+11.08080
    • 500+10.70280
    • 1000+10.53000
    POW-1644L-B-R
    • 1+34.539751+4.46227
    • 10+26.3171210+3.39997
    • 25+23.7461325+3.06782
    • 50+22.0031750+2.84264
    • 100+20.41564100+2.63754
    • 300+18.18067300+2.34880
    • 500+17.24505500+2.22793
    • 1000+16.069311000+2.07603
    • 5000+15.198045000+1.96347
    库存:579
