POW-1644P-B-R
POW-1644P-B-R
    PUIAUDIO
    MIC COND ANALOG OMNI -44DB
POW-1644P-B-R 数据手册
SPECIFICATIONS PARAMETERS VALUES UNITS DIRECTIVITY SENSITIVTY STANDARD OPERATING VOLTAGE MAX OPERATING VOLTAGE CURRENT CONSUMPTION (MAX) OMNI -44 3 2 10 0.5 2.2 60 -20 ~ +60 -40 ~ +70 PIN N/A - IMPEDANCE SIGNAL TO NOISE RATIO (MIN.) OPERATING TEMPERATURE STORAGE TEMPERATURE TERMINAL INTERNAL CAPACITOR THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. dB Vdc Vdc mA KOhm dB C C pF REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E RELEASED FROM ENGINEERING DELETED MOLEX CONNECTOR NOTE REVISED IP RATING REVISED TO INVENTOR 3-D DRAWING TEMPLATE ADDED TEMPERATURES AND PIN DIAMETER REVISED TEMPERATURE AND BOOT DIMENSIONS 10/19/2006 7/17/2007 7/2/2008 8/30/2008 1/29/2013 2/19/2020 D.F. B.R. B.R. B.R. M.V. ASSEMBLY B B B-B ( 7 : 1 ) 0.3 6 MICROPHONE 0.1 1.9 0.1 7 0.1 BOOT A 0.05 1.8 0.1 0.4 4.9 0.8 0.3 1.6 TERM. 2 (-) 3.2 0.2 A 2.6 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 5. ASSEMBLY IS WASHABLE WITH BOOT IN PLACE. 0.1 A-A ( 7 : 1 ) 1. ALL DIMENSIONS ARE IN MILLIMETERS. 4. PART IS IP57 RATED. 0.1 0.1 NOTES: 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 5.8 0.1 TERM. 1 (+) 2.8 0.1 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 POW-1644P-B-R.idw Designed by Date Checked by Date Approved by J.D. 10/19/2006 B.R. 10/20/2006 R.W. Date Drawn Date 10/20/2006 8/30/2008 POW-1644P-B-R Microphone Edition Sheet - 1/1
POW-1644P-B-R 价格&库存
很抱歉,暂时无法提供与“POW-1644P-B-R”相匹配的价格&库存,您可以联系我们找货
