POM-2740P-C33-R
POM-2740P-C33-R
    PUIAUDIO
    MIC COND ANALOG OMNI -40DB
POM-2740P-C33-R 数据手册
SPECIFICATIONS PARAMETERS DIRECTIVITY SENSITIVTY STANDARD OPERATING VOLTAGE MAX OPERATING VOLTAGE CURRENT CONSUMPTION (MAX) IMPEDANCE SIGNAL TO NOISE RATIO (MIN.) TERMINAL INTERNAL CAPACITOR VALUES UNIT OMINI -40 3 2 10 0.5 2.2 60 PIN 33 - THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED DIMENSIONS 3/23/2006 10/6/2010 2/14/2020 B.R. M.V. dB Vdc Vdc mA KOhm dB pF 2.8 6 REVISION HISTORY 0.3 2.7 0.2 1.9 0.1 0.4 0.1 0.05 0.8 TERM 2 (-) TERM 1 (+) 0.2 0.1 0.1 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 4. MICROPHONE CLOTH OVER FACE IS IP51 RATED. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 POM-2740P-C33-R.idw Designed by Date Checked by Date Approved by T.G. 3/23/2006 B.R. 3/23/2006 E.P. Date Drawn Date 3/23/2006 10/6/2010 POM-2740P-C33-R Microphone Edition Sheet - 1/1
POM-2740P-C33-R 价格&库存
很抱歉,暂时无法提供与“POM-2740P-C33-R”相匹配的价格&库存,您可以联系我们找货
POM-2740P-C33-R
    • 1+9.43920
    • 200+3.66120
    • 500+3.53160
    • 1000+3.46680
