AOW-4542P-B-R
AOW-4542P-B-R
    PUIAUDIO
    MIC COND ANALOG OMNI -42DB
AOW-4542P-B-R 数据手册
SPECIFICATIONS PARAMETERS VALUES UNITS DIRECTIVITY OMNI - SENSITIVTY -42 3 1.5 Vdc MAX OPERATING VOLTAGE CURRENT CONSUMPTION (MAX) 10 Vdc 0.5 mA 2.2 KOhm 60 PIN N/A dB pF TERMINAL INTERNAL CAPACITOR REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED IP RATING REVISED TO INVENTOR 3-D DRAWING TEMPLATE 10/10/2006 6/30/2008 8/31/2008 B.R. B.R. 2003, Projects Unlimited Inc. dB STANDARD OPERATING VOLTAGE IMPEDANCE SIGNAL TO NOISE RATIO (MIN.) THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. ASSEMBLY B B B-B ( 4 : 1 ) BOOT MICROPHONE 9.7 0.1 4.5 0.2 2.5 11.5 0.1 0.1 A 9.6 2 5 NOTES: +0.1 6.2 - 0 5 0.1 +0.1 3 -0 Positive (+) 0.1 A A-A ( 5 : 1 ) 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 4. PART IS IP57 RATED. 5. ASSEMBLY IS WASHABLE WITH BOOT IN PLACE. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AOW-4542P-B-R.idw Designed by Date Checked by Date Approved by J.D. 10/10/2006 B.R. 10/11/2006 R.W. Date Drawn Date 10/11/2006 8/31/2008 AOW-4542P-B-R Microphone Edition Sheet - 1/1
AOW-4542P-B-R 价格&库存
很抱歉,暂时无法提供与“AOW-4542P-B-R”相匹配的价格&库存,您可以联系我们找货
