POM-2246L-C33-LW100-R
    PUIAUDIO
    MICCONDANALOGOMNI-46DB
POM-2246L-C33-LW100-R 数据手册
SPECIFICATIONS PARAMETERS DIRECTIVITY SENSITIVTY STANDARD OPERATING VOLTAGE MAX OPERATING VOLTAGE CURRENT CONSUMPTION (MAX) IMPEDANCE SIGNAL TO NOISE RATIO (MIN.) TERMINAL INTERNAL CAPACITOR FREQUENCY RESPONSE VALUES UNIT OMNI -46 3 2 10 0.5 2.2 >55 LEAD WIRES 33 50 - 16,000 - THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED - RELEASED FROM ENGINEERING 7/15/2015 B.R. dB Vdc Vdc mA KOhm dB pF Hz UL3302 32 AWG Wires 100 6 5 0.1 1.5 0.5 2.2 Red + Black - 0.2 0.2 0.1 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 4. MICROPHONE CLOTH OVER FACE IS IP51 RATED. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . Designed by Date Checked by Date Approved by M.V. 7/15/2015 M.V. 7/15/2015 B.R. SIZE A3 POM-2246L-C33-LW100-R.idw Date Drawn Date 7/15/2015 7/15/2015 POM-2246L-C33-LW100-R Microphone Edition Sheet - 1/1
POM-2246L-C33-LW100-R 价格&库存
很抱歉,暂时无法提供与“POM-2246L-C33-LW100-R”相匹配的价格&库存,您可以联系我们找货
