SPECIFICATIONS
PARAMETERS
DIRECTIVITY
SENSITIVTY
STANDARD OPERATING VOLTAGE
MAX OPERATING VOLTAGE
CURRENT CONSUMPTION (MAX)
IMPEDANCE
SIGNAL TO NOISE RATIO (MIN.)
TERMINAL
INTERNAL CAPACITOR
VALUES
UNIT
OMINI
-46 3
2
10
0.5
2.2
62
SOLDER PADS
N/A
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
LTR
DESCRIPTION
DATE
APPROVED
A
B
RELEASED FROM ENGINEERING
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED DIMENSIONS AND SIGNAL TO NOISE RATIO
1/30/2006
10/21/2010
2/14/2020
B.R.
M.V.
dB
Vdc
Vdc
mA
KOhm
dB
pF
5
6
REVISION HISTORY
0.2
0.1
TERM 1 (+)
TERM 2 (-)
0.2
0.1
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
POM-5246L-R.idw
Designed by
Date
Checked by
Date
Approved by
J.A.F.
1/30/2006
E.P.
1/30/2006
B.R.
Date
Drawn Date
1/30/2006 10/21/2010
POM-5246L-R
Microphone
Edition
Sheet
1/1
很抱歉,暂时无法提供与“POM-5246L-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.71120
- 200+2.99160
- 500+2.88360
- 1000+2.82960
