4715MS-12T-B30-A00
4715MS-12T-B30-A00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 119X38MM 115VAC TERM
4715MS-12T-B30-A00 数据手册
11938MB (119 X 38L) Legacy Part No. 4715MS NMBTC.COM / 248.919.2250 Characteristic Curves Motor Structure: Shaded Pole Induction Motor Motor Protection: Impedance Protection Insulation Resistance: 100M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 1800V 3s Allowable Ambient Temperature Range: In H2O (Pa) .32 80 .24 60 .16 40 Ps .08 20 Static Pressure General Specifications -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) 0 0 1 2 3 70 106 4 (m3/min) 140 CFM Air Flow .24 60 .16 40 Ps .08 20 Static Pressure 100,000 Hours Material : Aluminum (Black Painting) : Plastic (Black) UL94V-0 : Ball Bearing : AWG22, UL3266 : Faston #110 or equivalent 60Hz 50Hz K 0 0 1 35 2 3 70 106 4 (m3/min) 141 CFM Air Flow Panel Cut-Outs In H2O (Pa) .32 80 4.14 (105) φ 11 4.5 6. 9 5) (φ 4.56 (115) .169 4 – (φ4.3 ± 0.2) .24 60 .16 40 Ps .08 20 Static Pressure inch Units: (mm) 0 4.14 (105) 4.56 (115) L 0 1 35 2 3 70 106 4 (m3/min) 140 CFM Air Flow In H2O (Pa) 80 .32 .24 60 .16 40 Ps .08 20 Static Pressure INLET SIDE / OUTLET SIDE Outline .169 8 – (φ4.3 ± 0.2) 60Hz 50Hz ROTATION 0 0 60Hz 50Hz 1 35 M 2 3 70 106 4 (m3/min) 140 CFM AIR 1.50 ± .02 (38 ± 0.5) 4.13 ± .01 (105 ± 0.3) 4.69 ± .02 (119) (Pa) In H2O .32 80 .24 60 .16 40 Ps .08 20 Static Pressure NAME PLATE 4.13 ± .01 (105 ± 0.3) 4.69 ± .02 (119) Air Flow 0 Flange type 0 60Hz 50Hz 1 35 N 2 3 70 106 Air Flow 4 (m3/min) 141 CFM DC AC Axial Fans (Pa) In H2O .32 80 Failure Rate: 10% Casing Impeller Bearing Lead Wire or Terminal J 35 Expected Life 25°C 60Hz 50Hz 11938MB (119 X 38L) Legacy Part No. 4715MS NMBTC.COM / 248.919.2250 Specifications MODEL Rated Frequency Starting Current Input Speed Voltage Voltage Power LEGACY P/N (V) 11938MB-A0J-EA-00 4715MS-10T-B10-B00 AC Axial Fans 11938MB-A0K-EA-00 4715MS-10T-B20-B00 11938MB-A0M-EA-00 4715MS-10T-B40-B00 11938MB-A0N-EA-00 4715MS-10T-B50-B00 11938MB-A1J-EA-00 4715MS-12T-B10-A00 11938MB-A1K-EA-00 4715MS-12T-B20-A00 11938MB-A1L-EA-00 4715MS-12T-B30-A00 11938MB-A1M-EA-00 4715MS-12T-B40-A00 11938MB-A1N-EA-00 4715MS-12T-B50-A00 11938MB-B0N-EA-00 4715MS-20T-B50-B00 11938MB-B2J-EA-00 4715MS-22T-B10-B00 50 65 0.11 7.0 1350 45.9 1.30 .06 14.0 27.0 550 60 65 0.10 6.5 1450 49.4 1.40 .06 15.0 28.0 550 100 50 65 0.13 8.0 2100 70.6 2.00 .14 35.3 32.0 550 100 60 65 0.12 8.0 1900 67.1 1.90 .10 24.6 30.0 550 100 50 65 0.19 11.0 2400 81.2 2.30 .19 48.1 34.0 550 100 60 65 0.17 10.0 2600 88.3 2.50 .18 46.1 37.0 550 100 50 65 0.25 15.0 2450 84.7 2.40 .21 52.0 35.0 550 100 60 65 0.22 13.0 2750 95.3 2.70 .23 58.0 39.0 550 100 50 65 0.27 15.0 2600 88.3 2.50 .26 64.7 37.0 550 100 60 65 0.23 14.0 2900 102.4 2.90 .31 76.4 41.0 550 115 50 75 0.09 6.0 1350 45.9 1.30 .06 15.6 27.0 550 115 60 75 0.08 5.5 1450 49.4 1.40 .07 16.6 28.0 550 115 50 75 0.10 7.0 2100 76.6 2.00 .14 35.2 32.0 550 115 60 75 0.10 7.0 1950 67.0 1.90 .10 24.5 30.0 550 115 50 75 0.16 11.0 2400 81.0 2.30 .20 49.9 34.0 550 115 60 75 0.14 10.0 2600 88.2 2.50 .20 49.9 37.0 550 115 50 75 0.22 15.0 2450 85.0 2.40 .20 50.9 35.0 550 115 60 75 0.19 13.0 2750 95.0 2.70 .26 64.6 39.0 550 115 50 65 0.25 15.5 2600 88.2 2.50 .26 64.6 37.0 550 115 60 65 0.21 14.5 2900 102.0 2.90 .31 76.4 41.0 550 200 50 130 0.06 6.0 1350 45.9 1.30 .06 14.0 27.0 550 200 60 130 0.05 5.5 1450 49.4 1.40 .06 15.0 28.0 550 200 50 130 0.06 7.0 2100 70.6 2.00 .13 32.3 32.0 550 200 60 130 0.06 7.0 1900 67.1 1.90 .08 20.5 30.0 550 200 50 130 0.09 10.0 2400 81.2 2.30 .19 48.1 34.0 550 200 60 130 0.08 10.0 2600 88.3 2.50 .18 46.1 37.0 550 200 50 130 0.13 15.0 2450 84.7 2.40 .21 52.0 35.0 550 200 60 130 0.11 13.0 2750 95.3 2.70 .23 58.0 39.0 550 200 50 130 0.14 15.0 2600 88.3 2.50 .26 64.7 37.0 550 200 60 130 0.12 13.0 2900 102.4 2.90 .31 76.5 41.0 550 220 50 145 0.05 6.0 1350 45.9 1.30 .06 14.0 27.0 550 11938MB-B2K-EA-00 4715MS-22T-B20-B00 11938MB-B2L-EA-00 4715MS-22T-B30-B00 (g) 100 11938MB-B0L-EA-00 4715MS-20T-B30-B00 11938MB-B0M-EA-00 4715MS-20T-B40-B00 (Pa)*2 (dB)*2 100 11938MB-B0J-EA-00 4715MS-20T-B10-B00 11938MB-B0K-EA-00 4715MS-20T-B20-B00 Mass (V) 11938MB-A0L-EA-00 4715MS-10T-B30-B00 (W) (min-1)*2 CFM*1 (m3/min)*2 in H2O Noise (Hz) (A)*1 Max. Max. Static Air Flow Pressure 220 60 145 0.04 5.5 1450 49.4 1.40 .06 15.0 28.0 550 220 50 145 0.06 7.0 2100 70.6 2.00 .13 31.4 32.0 550 220 60 145 0.06 7.0 1900 67.1 1.90 .08 19.6 30.0 550 220 50 145 0.09 11.0 2400 81.2 2.30 .19 48.1 34.0 550 11938MB-B2M-EA-00 4715MS-22T-B40-B00 11938MB-B2N-EA-00 4715MS-22T-B50-B00 220 60 145 0.08 10.0 2600 88.3 2.50 .18 46.1 37.0 550 220 50 145 0.11 14.0 2450 84.7 2.40 .21 52.0 35.0 550 220 60 145 0.10 12.0 2750 95.3 2.70 .23 58.0 39.0 550 220 50 145 0.12 14.0 2600 88.3 2.50 .26 63.8 37.0 550 220 60 145 0.10 13.0 2900 102.4 2.90 .30 75.6 41.0 550 11938MB (119 X 38L) Legacy Part No. 4715MS NMBTC.COM / 248.919.2250 Specifications MODEL Rated Frequency Starting Current Input Speed Voltage Voltage Power LEGACY P/N (V) 11938MB-B3J-EA-00 4715MS-23T-B10-A00 AC Axial Fans 550 50 175 0.05 6.5 1350 45.9 1.30 .06 14.7 27.0 230 60 175 0.05 6.0 1450 49.4 1.40 .59 14.7 28.0 550 230 50 175 0.06 7.5 2100 70.6 2.00 .14 35.2 32.0 550 230 60 175 0.06 7.5 1900 67.0 1.90 .09 21.5 30.0 550 230 50 175 0.10 12.0 2400 81.0 2.30 .20 49.0 34.0 550 230 60 175 0.08 11.0 2600 88.2 2.50 .21 51.9 37.0 550 230 50 175 0.12 15.0 2450 85.0 2.40 .22 53.9 35.0 550 230 60 175 0.10 13.0 2750 95.0 2.70 .26 63.7 39.0 550 230 50 175 0.12 15.0 2600 88.2 2.50 .26 63.7 37.0 550 230 60 175 0.10 14.0 2900 102.0 2.90 .28 70.5 41.0 550 240 50 175 0.05 6.5 1350 45.9 1.30 .06 14.0 27.0 550 240 60 175 0.05 6.0 1450 49.4 1.40 .06 15.0 28.0 550 240 50 175 0.06 8.0 2100 70.6 2.00 .15 38.2 32.0 550 240 60 175 0.06 8.0 1900 67.1 1.90 .10 24.6 30.0 550 240 50 175 0.09 12.0 2400 81.2 2.30 .19 48.1 34.0 550 240 60 175 0.08 11.0 2600 88.3 2.50 .18 46.1 37.0 550 240 50 140 0.10 13.0 2450 84.7 2.40 .21 52.0 35.0 550 240 60 140 0.08 12.0 2750 95.3 2.70 .23 58.0 39.0 550 240 50 140 0.11 14.0 2600 88.3 2.50 .30 63.8 37.0 550 60 140 0.10 13.0 2900 102.4 2.90 .30 65.7 41.0 550 11938MB-B4N-EA-00 240 Rotation: Counterclockwise Contact NMB for Availability ** (g) 230 11938MB-B4L-EA-00 4715MS-24T-B30-A00 11938MB-B4M-EA-00 4715MS-24T-B40-A00 (Pa)*2 (dB)*2 (A)*1 11938MB-B3N-EA-00 4715MS-23T-B50-A00 11938MB-B4K-EA-00 4715MS-24T-B20-A00 Mass (V) 11938MB-B3M-EA-00 4715MS-23T-B40-A00 11938MB-B4J-EA-00 4715MS-24T-B10-A00 (W) (min-1)*2 CFM*1 (m3/min)*2 in H2O Noise (Hz) 11938MB-B3K-EA-00 4715MS-23T-B20-A00 11938MB-B3L-EA-00 4715MS-23T-B30-A00 Max. Max. Static Air Flow Pressure Airflow Outlet: Air Out Over Struts *1: Maximum Values in Free Air *2: Average Values in Free Air *3: Minimum Values in Free Air
4715MS-12T-B30-A00 价格&库存
很抱歉,暂时无法提供与“4715MS-12T-B30-A00”相匹配的价格&库存,您可以联系我们找货
