4715FS-12T-B40-D00
4715FS-12T-B40-D00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 119X38MM 115VAC TERM
4715FS-12T-B40-D00 数据手册
4715FS (119 X 38L) EMINEBEA.COM -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Motor Structure: Shaded Pole Induction Motor Motor Protection: Impedance Protection inch Units: (mm) .169 4 – (φ4.3) NAME PLATE AIR 4.13 ±.01 (105 ±0.3) 4.69 ±.02 (119) (φ φ4 11 .5 6. 9 5) 4.56 (115) ROTATION 4.14 (105) .169 8 – (φ4.3) 4.14 (105) 4.56 (115) INLET SIDE / OUTLET SIDE 4.13 ±.01 (105 ±0.3) 4.69 ±.02 (119) 1.50 ±.02 (38 ±0.5) Rated MODEL Frequency Voltage Flange type Casing : Aluminum Alloy Impeller : UL94V-O Reinforced Plastic Bearing : Ball Bearings Lead Wire: AWG22, UL3266, CSA CL1252 or Terminal : Faston #110 or equivalent Starting Current Voltage Speed Max. Max. Static Air Flow Pressure Noise Mass (dB)*2 (g) (W)+10% -20% (min-1)*2 0.090 7.5 1700 60.0 1.70 .08 20.0 31 550 0.110 10.0 1900 70.0 1.98 .12 30.0 33 550 9.8 2300 80.0 2.25 .13 32.5 36 550 14.5 2650 90.0 2.50 .22 55.0 39 550 14.0 2800 100.0 2.80 .29 72.5 42 550 0.190 14.4 3100 110.0 3.10 .37 92.5 45 550 175 0.030 5.5 1600 55.0 1.50 .07 17.5 55 550 175 0.050 9.0 1900 70.0 1.98 .12 30.0 70 550 60 175 0.050 8.8 2300 80.0 2.25 .13 32.5 80 550 60 175 0.090 12.0 2650 90.0 2.50 .22 55.0 90 550 14.0 3300 100.0 2.80 .28 70.0 100 550 14.0 3100 110.0 3.10 .37 92.5 110 550 (V) (Hz) (V ) (A)*1 4715FS-12T-B00-D00 115 60 75 4715FS-12T-B10-D00 115 60 75 4715FS-12T-B20-D00 115 60 75 0.100 4715FS-12T-B30-D00 115 60 75 0.180 4715FS-12T-B40-D00 115 60 75 0.170 4715FS-12T-B50-D00 115 60 75 4715FS-23T-B00-D00 230 60 4715FS-23T-B10-D00 230 60 4715FS-23T-B20-D00 230 4715FS-23T-B30-D00 230 4715FS-23T-B40-D00 230 60 175 0.090 4715FS-23T-B50-D00 230 60 175 0.080 Rotation: Counterclockwise Input Power Airflow Outlet: Air In Over Struts CFM*2 (m3/min)*2 in H2O *1: Maximum Values in Free Air (Pa)*2 *2: Average Values in Free Air
4715FS-12T-B40-D00 价格&库存
很抱歉,暂时无法提供与“4715FS-12T-B40-D00”相匹配的价格&库存,您可以联系我们找货
