3115PS-23T-B30-A00
3115PS-23T-B30-A00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 80X38MM 230VAC TERM
3115PS-23T-B30-A00 数据手册
08038PB (80 X 38L) Legacy Part No. 3115PS NMBTC.COM / 248.919.2250 Characteristic Curves Motor Structure: Shaded Pole Induction Motor Motor Protection: Impedance Protection Insulation Resistance: 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: Ps (Pa) .24 60 .16 40 .08 20 Expected Life 25°C K J 0 0.2 7 100,000 Hours Material Casing Impeller Bearing Lead Wire or Terminal 60Hz 50Hz L Failure Rate: 10% 0.6 0.8 1.0 (m3/min) 14 21 Air Flow 28 35 CFM 0.4 Outline : Aluminum (Black Painting) : Plastic (Black) UL94V-0 : Ball Bearing : AWG22, UL3266 : Faston #110 or equivalent .169 8 – (φ4.3 ± 0.2) AIR (3.4) Panel Cut-Outs inch Units: (mm) 2.815 (71.5) φ (φ 3.4 88 6 .0 ) .169 4 – (φ4.3) 3.03 (77) AC Axial Fans -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) In H2O Static Pressure General Specifications 2.815 (71.5) 3.03 (77) INLET SIDE / OUTLET SIDE ROTATION NAME PLATE Flange Type 08038PB (80 X 38L) Legacy Part No. 3115PS NMBTC.COM / 248.919.2250 Specifications MODEL LEGACY P/N Rated Frequency Starting Current Input Speed Voltage Voltage Power (V) ** ** (W) (min-1)*2 CFM*1 (m3/min)*2 in H2O Noise Mass (Pa)*2 (dB)*2 (g) 270 (Hz) (V) (A)*1 100 08038PB-A0J-EA-00 3115PS-10T-B10-B00 100 50 65 0.065 4.5 1700 17.6 0.50 .06 16.6 23.0 60 65 0.055 4.0 1900 19.4 0.55 .08 21.5 25.0 270 08038PB-A0K-EA-00 3115PS-10T-B20-B00 100 50 65 0.080 4.5 2100 21.0 0.60 .10 24.5 29.0 270 100 60 65 0.070 4.0 2300 24.0 0.68 .12 29.4 32.0 270 08038PB-A0L-EA-00 3115PS-10T-B30-B00 100 50 65 0.170 9.0 2700 26.5 0.75 .14 34.3 33.0 270 100 60 65 0.120 7.0 3200 32.0 0.90 .20 49.0 38.0 270 08038PB-A1J-EA-00 3115PS-12T-B10-A00 115 50 75 0.060 4.5 1700 17.6 0.50 .06 16.6 23.0 270 115 60 75 0.055 4.0 1900 19.4 0.55 .08 21.5 25.0 270 08038PB-A1K-EA-00 3115PS-12T-B20-A00 115 50 75 0.080 5.0 2100 21.0 0.60 .10 24.5 29.0 270 115 60 75 0.070 4.5 2300 24.0 0.68 .12 29.4 32.0 270 115 08038PB-A1L-EA-00 3115PS-12T-B30-A00 115 50 75 0.140 9.0 2700 26.5 0.75 .14 34.3 33.0 270 60 75 0.110 7.0 3200 32.0 0.90 .20 49.0 38.0 270 ** 200 08038PB-B0J-EA-00 3115PS-20T-B10-B00 200 50 130 0.045 4.5 1700 17.6 0.50 .06 16.6 23.0 270 60 160 0.040 4.0 1900 19.4 0.55 .08 21.5 26.0 270 ** 200 08038PB-B0K-EA-00 3115PS-20T-B20-B00 200 50 130 0.040 4.5 2100 21.0 0.60 .10 24.5 29.0 270 60 160 0.035 4.0 2300 24.0 0.68 .13 31.3 32.0 270 ** 200 08038PB-B0L-EA-00 3115PS-20T-B30-B00 200 50 130 0.080 9.0 2700 26.5 0.75 .14 34.3 33.0 270 60 130 0.060 7.0 3200 32.0 0.90 .20 49.0 38.0 270 ** 220 08038PB-B2J-EA-00 3115PS-22T-B10-B00 220 50 150 0.050 5.5 1750 17.6 0.50 .06 16.6 23.0 270 60 150 0.045 4.5 2000 21.2 0.60 .09 23.5 26.0 270 ** 220 08038PB-B2K-EA-00 3115PS-22T-B20-B00 220 50 165 0.045 6.0 2200 22.0 0.63 .10 24.5 29.0 270 60 165 0.040 5.0 2400 25.4 0.72 .13 31.3 34.0 270 ** 220 08038PB-B2L-EA-00 3115PS-22T-B30-B00 220 50 150 0.070 9.0 2700 26.5 0.75 .14 34.3 33.0 270 60 150 0.060 7.0 3200 32.0 0.90 .20 49.0 38.0 270 230 08038PB-B3J-EA-00 3115PS-23T-B10-A00 230 50 150 0.055 6.0 1800 17.6 0.50 .07 17.6 23.0 270 60 150 0.050 5.0 2100 22.0 0.63 .10 24.5 26.0 270 230 08038PB-B3K-EA-00 3115PS-23T-B20-A00 230 50 150 0.050 7.0 2200 22.0 0.63 .10 24.5 30.0 270 60 150 0.045 6.0 2500 26.0 0.74 .14 35.2 34.0 270 230 08038PB-B3L-EA-00 3115PS-23T-B30-A00 230 50 150 0.070 10.0 2700 26.5 0.75 .14 34.3 33.0 270 60 150 0.055 8.0 3200 32.0 0.90 .20 49.0 38.0 270 ** 240 08038PB-B4J-EA-00 3115PS-24T-B10-A00 240 50 150 0.060 7.0 1800 17.6 0.50 .07 17.6 23.0 270 60 150 0.055 6.0 2150 21.6 0.64 .10 25.4 26.0 270 ** 240 08038PB-B4K-EA-00 3115PS-24T-B20-A00 240 50 150 0.055 7.0 2200 22.0 0.63 .10 24.5 30.0 270 60 150 0.045 6.0 2600 26.5 0.75 .15 37.2 35.0 270 ** 240 08038PB-B4L-EA-00 3115PS-24T-B30-A00 240 50 150 0.075 12.0 2700 26.5 0.75 .14 34.3 33.0 270 60 150 0.060 9.0 3200 32.0 0.90 .20 49.0 38.0 270 Rotation: Counterclockwise Contact NMB for Availability ** Airflow Outlet: Air Out Over Struts *1: Maximum Values in Free Air *2: Average Values in Free Air *3: Minimum Values in Free Air DC AC Axial Fans ** Max. Max. Static Air Flow Pressure
3115PS-23T-B30-A00 价格&库存
很抱歉,暂时无法提供与“3115PS-23T-B30-A00”相匹配的价格&库存,您可以联系我们找货
