5915PC-23T-B10-A00
5915PC-23T-B10-A00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 172X38MM 230VAC TERM
5915PC-23T-B10-A00 数据手册
15038PB (150 X Ø 172 X 38L) Legacy Part No. 5915PC Plastic Blades/Standard NMBTC.COM / 248.919.2250 General Specifications Characteristic Curves Motor Structure: Capacitor-Run Induction Motor Motor Protection: J ~ K Impedance Protection 100M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 1800V 3s Allowable Ambient Temperature Range: -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Static Pressure L Thermal Protection Insulation Resistance: (Pa) In H2O 300 .12 Ps L .8 200 .4 100 K J 0 Failure Rate: 10% 2 4 70 141 212 (m3/min) CFM Air Flow 100,000 Hours Material Casing Impeller Bearing Lead Wire or Terminal 6 Outline : Aluminum (Black Painting) : Plastic (Black) UL94V-0 : Ball Bearing : SPT-1 2X0.824mm2 AWG18 : Faston #110 or equivalent min 300 (11.81) From capacitor cover M4 - min .20 (M4 - min 5mm) Depth for Ground Terminal 1.57 (40 ± 3) .39 (10 ± 2) NO SOLDER 6.378 .008 (162 0.2 ) 6.77 .04 (172 1) Outline inch Units: (mm) 5.75 (146) .169 2 – (φ4.3 ± 0.2) 6.375 (162) 5 (φ .94 15 5 1) .24 .02 .169 (6) 1.5 2 – ( 4.3) (38 INLET SIDE / OUTLET SIDE .24 (6) 0.2 ) .008 .02 5.90 (150 1 ) .169 2 – ( 4.3) DC AC Axial Fans 0 Expected Life 25°C 60Hz 50Hz 15038PB (150 X Ø 172 X 38L) NMBTC.COM / 248.919.2250 Legacy Part No. 5915PC Plastic Blades/Standard Specifications MODEL LEGACY P/N Rated Frequency Starting Current Input Speed Voltage Voltage Power (V) ** AC Axial Fans ** ** Noise Mass (V) (A)*1 (W) (min-1)*2 CFM*1 (m3/min)*2 in H2O (Pa)*2 (dB)*2 (g) 100 15038PB-A0J-EA-00 5915PC-10T-B10-B00 100 50 65 0.170 16.0 1400 84.7 2.40 .173 43.1 35.0 60 65 0.020 18.0 1650 102.3 2.90 .243 60.7 38.0 800 15038PB-A0K-EA-00 5915PC-10T-B20-B00 100 50 65 0.250 22.0 2200 141.2 4.00 .393 98.0 46.0 800 100 60 65 0.230 23.0 2600 166.0 4.70 .472 117.6 50.0 800 15038PB-A0L-EP-00 5915PC-10T-B30-B00 100 50 65 0.470 37.0 2700 176.5 5.00 .629 156.8 52.0 800 100 60 65 0.440 33.0 3200 212.0 6.00 .865 215.6 56.0 800 15038PB-A1J-EA-00 5915PC-12T-B10-A00 115 50 75 0.160 16.0 1400 84.7 2.40 .173 43.1 35.0 800 15038PB-A1K-EA-00 5915PC-12T-B20-A00 15038PB-A1L-EP-00 5915PC-12T-B30-A00 ** (Hz) Max. Max. Static Air Flow Pressure 15038PB-B0J-EA-00 5915PC-20T-B10-B00 800 115 60 75 0.190 18.0 1650 102.3 2.90 .243 60.7 38.0 800 115 50 75 0.200 21.0 2200 141.2 4.00 .393 98.0 46.0 800 115 60 75 0.210 22.0 2600 166.0 4.70 .472 117.6 50.0 800 115 50 75 0.380 35.0 2700 176.5 5.00 .629 156.8 52.0 800 115 60 75 0.360 32.0 3200 212.0 6.00 .865 215.6 56.0 800 200 50 130 0.110 16.0 1400 84.7 2.40 .169 42.1 35.0 800 200 60 130 0.130 18.0 1650 102.3 2.90 .243 60.7 38.0 800 200 50 130 0.120 22.0 2200 141.2 4.00 .393 98.0 46.0 800 ** 15038PB-B0K-EA-00 5915PC-20T-B20-B00 200 60 130 0.140 23.0 2600 166.0 4.70 .472 117.6 50.0 800 ** 200 15038PB-B0L-EP-00 5915PC-20T-B30-B00 200 50 130 0.236 34.0 2700 176.5 5.00 .629 156.8 52.0 800 60 130 0.210 33.0 3200 212.0 6.00 .865 215.6 56.0 800 ** 220 15038PB-B2J-EA-00 5915PC-22T-B10-B00 220 50 130 0.100 16.0 1400 84.7 2.40 .169 42.1 35.0 800 60 130 0.120 18.0 1650 102.3 2.90 .243 60.7 38.0 800 ** 220 15038PB-B2K-EA-00 5915PC-22T-B20-B00 220 50 145 0.110 23.0 2200 141.2 4.00 .393 98.0 46.0 800 60 145 0.130 26.0 2600 166.0 4.70 .472 117.6 50.0 800 220 50 145 0.210 40.0 2700 176.5 5.00 .629 156.8 52.0 800 ** 15038PB-B2L-EP-00 5915PC-22T-B30-B00 220 60 145 0.180 38.0 3200 212.0 6.00 .865 215.6 56.0 800 230 15038PB-B3J-EA-00 5915PC-23T-B10-A00 230 50 145 0.090 16.0 1400 84.7 2.40 .169 43.1 35.0 800 60 145 0.110 18.0 1650 102.3 2.90 .243 60.7 38.0 800 230 15038PB-B3K-EA-00 5915PC-23T-B20-A00 230 50 145 0.120 23.0 2200 141.2 4.00 .393 98.0 46.0 800 60 145 0.140 26.0 2600 166.0 4.70 .472 117.6 50.0 800 230 15038PB-B3L-EP-00 5915PC-23T-B30-A00 230 50 145 0.180 35.0 2700 176.5 5.00 .629 156.8 52.0 800 60 145 0.190 35.0 3200 212.0 6.00 .865 215.6 56.0 800 ** 240 15038PB-B4J-AA-00 5915PC-24T-B10-A00 240 50 145 0.090 16.0 1400 84.7 2.40 .169 42.1 35.0 800 60 145 0.110 18.0 1650 102.3 2.90 .243 60.7 38.0 800 ** 240 15038PB-B4K-AA-00 5915PC-24T-B20-A00 240 50 145 0.100 22.0 2200 141.2 4.00 .393 98.0 46.0 800 60 145 0.110 26.0 2600 166.0 4.70 .472 117.6 50.0 800 ** 240 15038PB-B4L-EP-00 5915PC-24T-B30-A00 240 50 155 0.180 34.0 2700 176.5 5.00 .629 156.8 52.0 800 60 155 0.170 34.0 3200 212.0 6.00 .865 215.6 56.0 800 Rotation: Counterclockwise Contact NMB for Availability ** Airflow Outlet: Air Out Over Struts *1: Maximum Values in Free Air *2: Average Values in Free Air *3: Minimum Values in Free Air
5915PC-23T-B10-A00 价格&库存
很抱歉,暂时无法提供与“5915PC-23T-B10-A00”相匹配的价格&库存,您可以联系我们找货
