15038PB (150 X Ø 172 X 38L)
Legacy Part No. 5915PC Plastic Blades/Standard
NMBTC.COM / 248.919.2250
General Specifications
Characteristic Curves
Motor Structure: Capacitor-Run Induction Motor
Motor Protection: J ~ K Impedance Protection
100M Ω or over with a DC500V Megger
Dielectric Withstand Voltage: AC 1800V 3s
Allowable Ambient Temperature Range:
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Static Pressure
L Thermal Protection
Insulation Resistance:
(Pa)
In H2O
300
.12
Ps
L
.8
200
.4
100
K
J
Failure Rate: 10%
2
4
70
141
212
(m3/min)
CFM
Air Flow
100,000 Hours
Material
Casing
Impeller
Bearing
Lead Wire
or Terminal
6
Outline
: Aluminum (Black Painting)
: Plastic (Black) UL94V-0
: Ball Bearing
: SPT-1 2X0.824mm2 AWG18
: Faston #110 or equivalent
min 300
(11.81) From capacitor cover
M4 - min .20
(M4 - min 5mm)
Depth for Ground Terminal
1.57
(40 ± 3)
.39
(10 ± 2)
NO SOLDER
6.378 .008
(162 0.2 )
6.77 .04
(172 1)
Outline
inch
Units: (mm)
5.75
(146)
.169
2 – (φ4.3 ± 0.2)
6.375
(162)
5
(φ .94
15 5
1)
.24 .02
.169
(6) 1.5
2 – ( 4.3)
(38
INLET SIDE / OUTLET SIDE
.24
(6)
0.2 )
.008
.02
5.90
(150 1 )
.169
2 – ( 4.3)
DC
AC Axial Fans
Expected Life
25°C
60Hz
50Hz
Specifications
MODEL
LEGACY P/N
Rated Frequency Starting Current Input Speed
Voltage
Voltage
Power
(V)
AC Axial Fans
Noise Mass
(V) (A)*1 (W) (min-1)*2 CFM*1 (m3/min)*2 in H2O
(Pa)*2 (dB)*2 (g)
100
15038PB-A0J-EA-00
5915PC-10T-B10-B00
100
50
65 0.170
16.0
1400
84.7
2.40
.173
43.1
35.0
60
65 0.020
18.0
1650
102.3
2.90
.243
60.7
38.0
800
15038PB-A0K-EA-00 5915PC-10T-B20-B00
100
50
65 0.250
22.0
2200
141.2
4.00
.393
98.0
46.0
800
100
60
65 0.230
23.0
2600
166.0
4.70
.472
117.6
50.0
800
15038PB-A0L-EP-00 5915PC-10T-B30-B00
100
50
65 0.470
37.0
2700
176.5
5.00
.629
156.8
52.0
800
100
60
65 0.440
33.0
3200
212.0
6.00
.865
215.6
56.0
800
15038PB-A1J-EA-00 5915PC-12T-B10-A00
115
50
75 0.160
16.0
1400
84.7
2.40
.173
43.1
35.0
800
15038PB-A1K-EA-00 5915PC-12T-B20-A00
15038PB-A1L-EP-00 5915PC-12T-B30-A00
(Hz)
Max. Max. Static
Air Flow Pressure
15038PB-B0J-EA-00 5915PC-20T-B10-B00
800
115
60
75 0.190
18.0
1650
102.3
2.90
.243
60.7
38.0
800
115
50
75 0.200
21.0
2200
141.2
4.00
.393
98.0
46.0
800
115
60
75 0.210
22.0
2600
166.0
4.70
.472
117.6
50.0
800
115
50
75 0.380
35.0
2700
176.5
5.00
.629
156.8
52.0
800
115
60
75 0.360
32.0
3200
212.0
6.00
.865
215.6
56.0
800
200
50
130 0.110
16.0
1400
84.7
2.40
.169
42.1
35.0
800
200
60
130 0.130
18.0
1650
102.3
2.90
.243
60.7
38.0
800
200
50
130 0.120
22.0
2200
141.2
4.00
.393
98.0
46.0
800
15038PB-B0K-EA-00 5915PC-20T-B20-B00
200
60
130 0.140
23.0
2600
166.0
4.70
.472
117.6
50.0
800
200
15038PB-B0L-EP-00 5915PC-20T-B30-B00
200
50
130 0.236
34.0
2700
176.5
5.00
.629
156.8
52.0
800
60
130 0.210
33.0
3200
212.0
6.00
.865
215.6
56.0
800
220
15038PB-B2J-EA-00 5915PC-22T-B10-B00
220
50
130 0.100
16.0
1400
84.7
2.40
.169
42.1
35.0
800
60
130 0.120
18.0
1650
102.3
2.90
.243
60.7 38.0
800
220
15038PB-B2K-EA-00 5915PC-22T-B20-B00
220
50
145 0.110
23.0
2200
141.2
4.00
.393
98.0
46.0
800
60
145 0.130
26.0
2600
166.0
4.70
.472
117.6
50.0
800
220
50
145 0.210
40.0
2700
176.5
5.00
.629
156.8
52.0
800
15038PB-B2L-EP-00 5915PC-22T-B30-B00
220
60
145 0.180
38.0
3200
212.0
6.00
.865
215.6
56.0
800
230
15038PB-B3J-EA-00 5915PC-23T-B10-A00
230
50
145 0.090
16.0
1400
84.7
2.40
.169
43.1
35.0
800
60
145 0.110
18.0
1650
102.3
2.90
.243
60.7
38.0
800
230
15038PB-B3K-EA-00 5915PC-23T-B20-A00
230
50
145 0.120
23.0
2200
141.2
4.00
.393
98.0
46.0
800
60
145 0.140
26.0
2600
166.0
4.70
.472
117.6
50.0
800
230
15038PB-B3L-EP-00 5915PC-23T-B30-A00
230
50
145 0.180
35.0
2700
176.5
5.00
.629
156.8
52.0
800
60
145 0.190
35.0
3200
212.0
6.00
.865
215.6
56.0
800
240
15038PB-B4J-AA-00 5915PC-24T-B10-A00
240
50
145 0.090
16.0
1400
84.7
2.40
.169
42.1
35.0
800
60
145 0.110
18.0
1650
102.3
2.90
.243
60.7
38.0
800
240
15038PB-B4K-AA-00 5915PC-24T-B20-A00
240
50
145 0.100
22.0
2200
141.2
4.00
.393
98.0
46.0
800
60
145 0.110
26.0
2600
166.0
4.70
.472
117.6
50.0
800
240
15038PB-B4L-EP-00 5915PC-24T-B30-A00
240
50
155 0.180
34.0
2700
176.5
5.00
.629
156.8
52.0
800
60
155 0.170
34.0
3200
212.0
6.00
.865
215.6
56.0
800
Rotation: Counterclockwise
Contact NMB for Availability
Airflow Outlet: Air Out Over Struts
*1: Maximum Values in Free Air
*2: Average Values in Free Air
*3: Minimum Values in Free Air
很抱歉,暂时无法提供与“5915PC-23T-B30-A00”相匹配的价格&库存,您可以联系我们找货
