4715MS-22T-B50-B00
4715MS-22T-B50-B00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 119X38MM 220VAC TERM
4715MS-22T-B50-B00 数据手册
4715MS (119 X 38L) EMINEBEA.COM -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) In H2O (Pa) .32 80 60 .16 40 Ps .08 20 Static Pressure Motor Structure: Shaded Pole Induction Motor Motor Protection: Impedance Protection .24 0 60Hz 50Hz B10 0 1 35 50,000 Hours .24 60 inch Units: (mm) .16 40 .169 8 – (�4.3 ± 0.2) Ps .08 20 ROTATION 0 40 Ps .08 20 Static Pressure .16 0 4.14 (105) 4.56 (115) INLET SIDE / OUTLET SIDE Casing : Aluminum Impeller : Polycarbonate (Glass Fiber-Containing) Bearing : Ball Bearings Lead Wire : AWG22, UL3266, CSA CLR52 or Terminal : Faston #110 or equivalent 106 140 CFM 1 2 3 4 70 106 (m3/min) 141 CFM Air Flow 60Hz 50Hz B30 0 0 1 2 3 35 70 106 4 (m3/min) 140 CFM Air Flow In H2O (Pa) .32 80 .24 60 .16 40 Ps .08 20 Static Pressure 4.14 (105) .169 4 – (�4.3 ± 0.2) (� �4 11 .5 6. 9 5) 60 Flange type inch Units: (mm) 4.56 (115) .24 70 (m3/min) B20 In H2O (Pa) .32 80 0 0 60Hz 50Hz .24 60 .16 40 Ps .08 20 0 0 B40 1 2 3 35 70 106 4 (m3/min) 140 CFM Air Flow (Pa) In H2O .32 80 Static Pressure 4.13 ± .01 (105 ± 0.3) 4.69 ± .02 (119) 1.50 ± .02 (38 ± 0.5) 4.13 ± .01 (105 ± 0.3) 4.69 ± .02 (119) AIR 4 60Hz 50Hz 35 NAME PLATE 3 Air Flow (Pa) In H2O .32 80 Static Pressure 25°C 2 60Hz 50Hz 1 35 B50 2 3 70 106 Air Flow 4 (m3/min) 141 CFM 4715MS (119 X 38L) EMINEBEA.COM Rated MODEL Frequency Voltage (V) 4715MS-10T-B50-B00 4715MS-12T-B50-A00 4715MS-20T-B50-B00 4715MS-22T-B50-B00 4715MS-23T-B50-A00 4715MS-24T-B50-A00 4715MS-10T-B40-B00 4715MS-12T-B40-A00 4715MS-20T-B40-B00 4715MS-22T-B40-B00 4715MS-23T-B40-A00 4715MS-24T-B40-A00 4715MS-10T-B30-B00 4715MS-12T-B30-A00 4715MS-20T-B30-B00 4715MS-22T-B30-B00 4715MS-23T-B30-A00 4715MS-24T-B30-A00 4715MS-10T-B20-B00 4715MS-12T-B20-A00 4715MS-20T-B20-B00 4715MS-22T-B20-B00 4715MS-23T-B20-A00 4715MS-24T-B20-A00 4715MS-10T-B10-B00 4715MS-12T-B10-A00 4715MS-20T-B10-B00 4715MS-22T-B10-B00 4715MS-23T-B10-A00 4715MS-24T-B10-A00 Rotation: Counterclockwise Starting Current Voltage (Hz) (V) Input Speed Power (A)*1 (W)+10% -20% (min-1)*2 Max. Max. Static Air Flow Pressure CFM*2 (m3/min)*2 in H2O (Pa)*2 Noise Mass (dB)*2 (g) 100 50 65 0.270 15.0 2600 88.25 2.50 .259 64.6 37.0 550 100 60 65 0.230 14.0 2900 102.0 2.90 .306 76.4 41.0 550 115 50 65 0.250 15.5 2600 88.2 2.50 .259 64.6 37.0 550 115 60 65 0.210 14.5 2900 102.0 2.90 .306 76.4 41.0 550 200 50 130 0.140 15.0 2600 88.25 2.50 .259 64.6 37.0 550 200 60 130 0.120 13.0 2900 102.0 2.90 .306 76.4 41.0 550 220 50 145 0.120 14.0 2600 88.25 2.50 .255 63.7 37.0 550 220 60 145 0.100 13.0 2900 102.0 2.90 .302 75.4 41.0 550 230 50 175 0.120 15.0 2600 88.2 2.50 .255 63.7 37.0 550 230 60 175 0.100 14.0 2900 102.0 2.90 .283 70.5 41.0 550 240 50 140 0.110 14.0 2600 88.25 2.50 .255 63.7 37.0 550 240 60 140 0.100 13.0 2900 102.0 2.90 .363 65.6 41.0 550 100 50 65 0.250 15.0 2450 85.0 2.40 .204 50.9 35.0 550 100 60 65 0.220 13.0 2750 95.0 2.70 .251 62.7 39.0 550 115 50 75 0.220 15.0 2450 85.0 2.40 .204 50.9 35.0 550 115 60 75 0.190 13.0 2750 95.0 2.70 .259 64.6 39.0 550 200 50 130 0.130 15.0 2450 85.0 2.40 .204 50.9 35.0 550 200 60 160 0.110 13.0 2750 95.0 2.70 .255 63.7 39.0 550 220 50 145 0.110 14.0 2450 85.0 2.40 .216 53.9 35.0 550 220 60 145 0.100 12.0 2750 95.0 2.70 .255 63.7 39.0 550 550 230 50 175 0.120 15.0 2450 85.0 2.40 .216 53.9 35.0 230 60 175 0.100 13.0 2750 95.0 2.70 .255 63.7 39.0 550 240 50 140 0.100 13.0 2450 85.0 2.40 .204 50.9 35.0 550 240 60 140 0.080 12.0 2750 95.0 2.70 .236 58.8 39.0 550 100 50 65 0.190 11.0 2400 81.0 2.30 .200 49.9 34.0 550 100 60 65 0.170 10.0 2600 88.2 2.50 .204 50.9 37.0 550 115 50 75 0.160 11.0 2400 81.0 2.30 .200 49.9 34.0 550 115 60 75 0.140 10.0 2600 88.2 2.50 .200 49.9 37.0 550 200 50 130 0.090 10.0 2400 81.0 2.30 .193 48.0 34.0 550 200 60 130 0.080 10.0 2600 88.2 2.50 .185 46.0 37.0 550 220 50 145 0.090 11.0 2400 81.0 2.30 .197 49.0 34.0 550 220 60 145 0.080 10.0 2600 88.2 2.50 .189 47.0 37.0 550 230 50 175 0.100 12.0 2400 81.0 2.30 .197 49.0 34.0 550 230 60 175 0.080 11.0 2600 88.2 2.50 .208 51.9 37.0 550 240 50 140 0.090 12.0 2400 81.0 2.30 .197 49.0 34.0 550 240 60 140 0.080 11.0 2600 88.2 2.50 .204 50.9 37.0 550 100 50 65 0.130 8.0 2100 76.5 2.00 .141 35.2 32.0 550 100 60 65 0.120 8.0 1950 67.0 1.90 .098 24.5 30.0 550 115 50 75 0.100 7.0 2100 70.6 2.00 .141 35.2 32.0 550 115 60 75 0.100 7.0 1950 67.0 1.90 .098 24.5 30.0 550 200 50 130 0.060 7.0 2100 70.6 2.00 .129 32.3 32.0 550 200 60 130 0.060 7.0 1950 67.0 1.90 .082 20.5 30.0 550 220 50 145 0.060 7.0 2100 70.6 2.00 .125 31.3 32.0 550 220 60 145 0.060 7.0 1900 67.0 1.90 .078 19.6 30.0 550 230 50 175 0.060 7.5 2100 70.6 2.00 .141 35.2 32.0 550 230 60 175 0.060 7.5 1900 67.0 1.90 .086 21.5 30.0 550 240 50 175 0.060 8.0 2100 70.6 2.00 .153 38.2 32.0 550 240 60 175 0.060 8.0 1900 67.0 1.90 .098 24.5 30.0 550 100 50 65 0.110 7.0 1350 45.9 1.30 .066 16.6 27.0 550 100 60 65 0.110 6.5 1450 49.4 1.40 .066 16.6 28.0 550 115 50 75 0.090 6.0 1350 45.9 1.30 .062 15.6 27.0 550 115 60 75 0.080 5.5 1450 49.4 1.40 .066 16.6 28.0 550 200 50 130 0.055 6.0 1350 45.9 1.30 .059 14.7 27.0 550 200 60 130 0.050 5.0 1450 49.4 1.40 .059 14.7 28.0 550 220 50 145 0.050 6.0 1350 45.9 1.30 .059 14.7 27.0 550 220 60 145 0.040 5.5 1450 49.4 1.40 .059 14.7 28.0 550 230 50 175 0.050 6.5 1350 45.9 1.30 .059 14.7 27.0 550 230 60 175 0.045 6.0 1450 49.4 1.40 .059 14.7 28.0 550 240 50 175 0.050 6.5 1350 45.9 1.30 .062 15.6 27.0 550 240 60 175 0.045 6.0 1450 49.4 1.40 .066 16.6 28.0 550 Airflow Outlet: Air Out Over Struts *1: Maximum Values in Free Air *2: Average Values in Free Air
4715MS-22T-B50-B00
物料型号:4715MS-10T-B50-800, 4715MS-12T-B50-A00, 4715MS-20T-B50-800, 4715MS-22T-B50-800, 4715MS-24T-B50-A00等。
器件简介:这些是AC轴流风扇,具有不同的额定电压、频率、启动电压、电流、输入功率、转速、最大空气流量、最大静压、噪音水平、质量等参数。
引脚分配:文档中没有提供引脚分配信息。
参数特性:包括允许的环境温度范围、电机结构、电机保护、预期寿命、故障率、尺寸、静态压力、空气流量等。
功能详解:文档提供了不同型号风扇在不同电压和频率下的性能曲线图。
应用信息:文档中没有提供具体的应用信息
封装信息:包括外壳材料(铝)、叶轮材料(含玻璃纤维的聚碳酸酯)、轴承类型(球轴承)、引线规格等。
4715MS-22T-B50-B00 价格&库存
很抱歉,暂时无法提供与“4715MS-22T-B50-B00”相匹配的价格&库存,您可以联系我们找货
