4715HS-23T-B50-AM0
4715HS-23T-B50-AM0
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 119X38MM 230VAC TERM
4715HS-23T-B50-AM0 数据手册
11938SB (119 X 38L) Legacy Part No. 4715HS Plastic Blades/Potting NMBTC.COM / 818.341.3355 Characteristic Curves General Specifications Motor Structure: Shaded Pole Induction Motor Motor Protection: Impedance Protection Insulation Resistance: In H2O (Pa) .48 .40 10M Ω or over with a DC500V Megger .32 Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: .24 -10°C ~ +65°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) .16 .08 AC Axial Fans Expected Life (m 3/min) Failure Rate: 10% 25°C 100,000 Hours 35 Material Casing Impeller Bearing Lead Wire or Terminal 70 106 141 CFM Outline : Aluminum (Black Painting) : Plastic (Black) UL94V-0 : Ball Bearings : AWG22, UL3266 : Faston #110 or equivalent ROTATION Panel Cut-Outs inch Units: (mm) 3.11 (7.9) .169 8 – ( 4.3) 4.13 (105 0.3 ) 4.69 (119 0.5 ) 4.13 (105) 5. 3 13 5 6) ( (115) 4.53 .169 4 – ( 4.3) 4.13 (105) 4.53 (115) 4.13 (105 0.3 ) 4.69 (119 0.5 ) 1.49 (38 0.5 ) INLET SIDE / OUTLET SIDE Specifications MODEL LEGACY P/N Rated Frequency Starting Current Input Speed Voltage Voltage Power (V) ** ** ** ** (Hz) (V) (A)*1 Max. Max. Static Air Flow Pressure (W) (min-1)*2 CFM*1 (m3/min)*2 in H2O Noise Mass (Pa)*2 (dB)*2 (g) 100 11938SB-A0N-QA-00 4715HS-10T-B50-BM0 100 50 65 0.370 18.0 2600 91.8 2.60 0.380 94.0 40 610 60 65 0.290 15.5 3100 105.9 3.00 0.400 100.0 44 610 11938SB-A1N-QA-U0 4715HS-12T-B50-AM0 115 50 75 0.320 18.0 2600 91.8 2.60 0.380 94.0 40 610 115 60 75 0.250 15.5 3100 105.9 3.00 0.400 100.0 44 610 200 50 130 0.180 18.0 2600 91.8 2.60 0.380 94.0 40 610 200 60 130 0.150 15.5 3100 105.9 3.00 0.400 100.0 44 610 220 11938SB-B2N-QA-00 4715HS-22T-B50-BM0 220 50 145 0.160 18.0 2600 91.8 2.60 0.380 94.0 40 610 60 145 0.130 15.5 3100 105.9 3.00 0.400 100.0 44 610 11938SB-B3N-QA-U0 4715HS-23T-B50-AM0 50 175 0.160 18.0 2600 91.8 2.60 0.380 94.0 40 610 11938SB-B0N-QA-00 4715HS-20T-B50-BM0 230 230 60 175 0.120 15.5 3100 105.9 3.00 0.400 100.0 44 610 240 11938SB-B4N-QA-00 4715HS-24T-B50-AM0 240 50 175 0.150 18.0 2600 91.8 2.60 0.380 94.0 40 610 60 175 0.120 15.5 3100 105.9 3.00 0.400 100.0 44 610 Rotation: Counterclockwise Contact NMB for Availability ** Airflow Outlet: Air Out Over Struts *1: Maximum Values in Free Air *2: Average Values in Free Air *3: Minimum Values in Free Air
4715HS-23T-B50-AM0 价格&库存
很抱歉,暂时无法提供与“4715HS-23T-B50-AM0”相匹配的价格&库存,您可以联系我们找货
