5915PC-12T-B30-S00
5915PC-12T-B30-S00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 172X38MM 115VAC TERM
5915PC-12T-B30-S00 数据手册
NE W ! 5915PC (150 X Ø 172 X 38L) Metal Blades/Potting NMBTC.COM / 818.341.3355 General Specifications Characteristic Curves Motor Structure: Capacitor-Run Induction Motor Motor Protection: Thermal Protection Insulation Resistance: In H2O .80 100M Ω or over with a DC500V Megger .56 Dielectric Withstand Voltage: AC 1800V 3s Allowable Ambient Temperature Range: .40 -10°C ~ +60°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) .24 Expected Life Failure Rate: 10% 25°C 50,000 Hours 35 245 CFM Outline Material 1) 6.378 (162 6.77 (172 .169 2 – ( 4.3) ( 5. 9 15 8 2) 5.75 (146) .24 .02 .169 (6) 2 – ( 4.3) 1.5 6.375 (162) inch Units: (mm) .008 Panel Cut-Outs .04 : Aluminum : Steel : Ball Bearing : Faston #110 or equivalent 0.2 ) Casing Impeller Bearing Terminal 175 106 AC Axial Fans .08 (38 .24 (6) .008 0.2 ) .02 .169 2 – ( 4.3) 5.90 (150 1 ) INLET SIDE / OUTLET SIDE Specifications Rated Frequency Starting Voltage MODEL (V) Current Voltage Input Speed Power (Hz) (V) (A)*1 (W)*1 (min-1)*3 Max. Air Flow Max. Static Noise Mass Pressure CFM (m3/min)*3 in H2O (Pa)*3 (dB)*2 (g) 5915PC-10T-B30-SM0 100 50 65 0.530 42.0 2650 187.10 5.30 0.510 127.5 48 950 5915PC-10T-B30-SM0 100 60 65 0.450 40.0 3150 222.39 6.30 0.655 163.8 53 950 5915PC-12T-B30-SM0 115 50 75 0.450 40.0 2650 187.10 5.30 0.510 127.5 48 950 5915PC-12T-B30-SM0 115 60 75 0.400 38.0 3150 222.39 6.30 0.655 163.8 53 950 5915PC-20T-B30-SM0 200 50 130 0.250 42.0 2650 187.10 5.30 0.510 127.5 48 900 5915PC-20T-B30-SM0 200 60 130 0.230 40.0 3150 222.39 6.30 0.655 163.8 53 950 5915PC-22T-B30-SM0 220 50 145 0.250 42.0 2650 187.10 5.30 0.510 127.5 48 900 5915PC-22T-B30-SM0 220 60 145 0.230 40.0 3150 222.39 6.30 0.655 163.8 53 950 5915PC-23T-B30-SM0 230 50 150 0.220 42.0 2650 187.10 5.30 0.510 127.5 48 950 5915PC-23T-B30-SM0 230 60 150 0.200 40.0 3150 222.39 6.30 0.655 163.8 53 950 5915PC-24T-B30-SM0 240 50 155 0.200 39.0 2650 187.10 5.30 0.510 127.5 48 950 5915PC-24T-B30-SM0 240 60 155 0.200 39.0 3150 222.39 6.30 0.655 163.8 53 950 Rotation: Counterclockwise Airflow Outlet: Air Out Over Struts *1: Maximum Values in Free Air *2: Average Values in Free Air *3: Minimum Values in Free Air 3.23
5915PC-12T-B30-S00 价格&库存
很抱歉,暂时无法提供与“5915PC-12T-B30-S00”相匹配的价格&库存,您可以联系我们找货
