08038FB (80 X 38L)
NMBTC.COM / 248.919.2250
Legacy Part No. 3115FS
General Specifications
Motor Structure: Shaded Pole Induction Motor
Motor Protection: Impedance Protection
Insulation Resistance:
In H2O (Pa)
55
.18
45
L
.14
35
K
.10
25
H
Ps .06
15
.02
5
Static Pressure
10M Ω or over with a DC500V Megger
.22
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Failure Rate: 10%
25°C
4
50,000 Hours
8
12
16 20 24 28 32 36
Air Flow
CFM
Outline
Material
Casing
Impeller
Bearing
Lead Wire
or Terminal
(m3/min)
.11 .22 .34 .45 .56 .65 .79 .90 1.0
: Aluminum
: UL94V-O Reinforced Plastic
: Ball Bearing
: AWG22, UL3266
: Faston #110 or equivalent
ROTATION
AIR
NAME PLATE
Panel Cut-Outs
inch
Units: (mm)
Flange Type
(3.4)
2.815
(71.5)
φ
(φ 3.4
88 6
.0
3.03
(77)
.169
4 – (φ4.3)
2.815
(71.5)
3.03
(77)
INLET SIDE / OUTLET SIDE
Specifications
MODEL
Rated Frequency Starting Current Input Speed
Voltage
Voltage
Power
LEGACY P/N
(V)
(Hz)
08038FB-A1H-EA-00 3115FS-12T-B00-A00
115
60
75 0.045
4.0
1850
18.0
0.51
3115FS-12T-B10-A00
115
60
75 0.087
6.5
2100
22.0
0.62
08038FB-A1K-EA-00 3115FS-12T-B20-A00
115
60
75 0.090
7.5
2700
27.0
0.76
08038FB-A1L-EA-00 3115FS-12T-B30-A00
115
60
75 0.100
8.5
3250
32.0
0.90
08038FB-A1J-EA-00
08038FB-B3J-EA-00
3115FS-23T-B10-A00 230
(V)
(A)*1
Max. Max. Static
Air Flow Pressure
(W) (min-1)*2 CFM*1 (m3/min)*2 in H2O
Noise Mass
(Pa)*2 (dB)*2
(g)
.07
17.5
31
340
.09
22.5
36
340
.13
32.5
40
340
.18
45.0
44
340
60
175 0.050
6.5
2050
20.0
0.57
.09
22.5
35
340
08038FB-B3K-EA-00 3115FS-23T-B20-A00
230
60
175 0.060
7.5
2750
28.0
0.79
.13
32.5
40
340
08038FB-B3L-EA-00 3115FS-23T-B30-A00
230
60
175 0.065
8.0
3250
33.0
0.93
.18
45.0
44
340
Rotation: Counterclockwise
Airflow Outlet: Air In Over Struts
*1: Maximum Values in Free Air
*2: Average Values in Free Air
*3: Minimum Values in Free Air
DC
AC Axial Fans
Expected Life
J
很抱歉,暂时无法提供与“3115FS-12W-B10-A00”相匹配的价格&库存,您可以联系我们找货
