4.69 ±0.02
(120 ±0.5)
1.50 ±0.02
(38 ±0.5)
4.12 ±0.01
(104.8 ±0.3)
.35
0.16
(4)
Ø0.17
(Ø4.3 ±0.2)
Ø4.49
(Ø114)
Nom. 11.8
(300)
STATIC PRESSURE - IN. OF WATER
AC AXIAL FANS
UF12AR series
.30
H
M
.25
L
.20
.15
.10
.05
(120 x 120 x 38 mm)
Reverse air flow
aluminum die cast frame;
UL94V-0 PBT impeller
Bearing option:
ball bearing or sintered bronze
sleeve
Motor:
shaded pole
Air Flow:
intake over struts
Connection:
terminal or 22 AWG lead wire
Protection:
impedance
w w w.mechatronic s.com
11.23.20
60
80
100
120
AIR FLOW (CFM)
TERMINAL TYPE
0.33
(8.5)
Operating voltage: 115 or 230 VAC
Construction:
40
0.12
(3)
4.69 x 4.69 x 1.5 inches
Features:
LEAD WIRE TYPE
Model No.
Rated Freq. Input Rated Locked Speed
Voltage
Power Cur.
Cur.
V
HZ
UF12AR12-_ _H
115
60
UF12AR23-_ _H
230
60
UF12AR12-_ _M
115
60
UF12AR23-_ _M
230
UF12AR12-_ _L
UF12AR23-_ _L
E - mail: S ales @ M echatronic s.com
0.31
(8)
M³/Min. CFM
INCH
dbA
kg
99
8.5
0.33
47
0.53
99
8.5
0.33
47
0.53
2.4
85
6.5
0.26
45
0.53
2,750
2.4
85
6.5
0.26
45
0.53
0.16
2,300
2.1
75
4.0
0.16
38
0.53
0.08
2,300
2.1
75
4.0
0.16
38
0.53
A
RPM
11
0.19
0.20
3,100
2.8
15
0.09
0.10
3,100
2.8
11
0.17
0.19
2,750
60
15
0.08
0.09
115
60
11
0.15
230
60
15
0.07
Tel: 425 -2 2 2- 5 9 0 0
Max. Static Sound Weight
Pressure (H2 0) Noise
MM
A
Fa x : 425 -2 2 2- 515 5
W
Air Volume
800-453-4569
Cooling Simplified
很抱歉,暂时无法提供与“UF12AR12-BTHR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+205.522701+26.55193
- 10+168.6547610+21.78888
- 40+147.7783140+19.09181
- 80+138.0461880+17.83449
- 120+132.61381120+17.13267
- 280+127.34390280+16.45184
