LPC15P12-BTER
LPC15P12-BTER
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL172X150X51MM115VACEC
LPC15P12-BTER 数据手册
0.70 0.12 ±0.01 (3.0 ±0.3) 0.12 ±0.01 (3.0 ±0.3) TATION RO M4 GRD 8x-0.17 (4.2) STATIC PRESSURE - IN. OF WATER 6.58 (167.15) 2.00 ±0.02 (51.0 ±0.5) 6.58 (167.15) 5.29 ±0.02 (134.3 ±0.5) 6.77 ±0.02 (172.0 ±0.5) 6.38 ±0.02 (162 ±0.5) 1.41 ±0.01 (35.7 ±0.3) 5.94 ±0.02 (151 ±0.5) AC AXIAL FANS LPC15P series* 0.60 E H 0.50 M 0.40 L 0.30 0.20 0.10 ø5.77 (146.5) 0 50 100 150 200 250 300 350 AIR FLOW CFM (172 x 150 x 51 mm) L=12.20 (310) 6.77 x 5.90 x 2.00 inches Features: Operating voltage: 115 or 230 VAC Construction: Terminal low power consumption, global input voltage magnesium die cast frame with UL94V-0 plastic impeller Bearing option: motor quality ball bearings Motor: electronically comutated Air Flow: air exhaust over struts Connection: terminal type or lead wire Lead Wire Freq. Input Power Speed Air Volume Max. Static Pressure (H2 0) Sound Noise Model No. Rated Voltage V HZ W RPM M³/Min. CFM MM INCH dbA g LPC15P12-__L 115 50/60 10 2,800 5.9 210 12.0 0.48 50 666 Weight LPC15P23-__L 230 50/60 10 2,800 5.9 210 12.0 0.48 50 666 LPC15P12-__M 115 50/60 16 3,200 6.7 235 13.8 0.55 53 666 LPC15P23-__M 230 50/60 16 3,200 6.7 235 13.8 0.55 53 666 LPC15P12-__H 115 50/60 22 3,600 7.4 260 15.8 0.63 56 666 666 LPC15P23-__H 230 50/60 22 3,600 7.4 260 15.8 0.63 56 LPC15P12-__E 115 50/60 29 4,000 8.2 290 17.5 0.70 61 666 LPC15P23-__E 230 50/60 29 4,000 8.2 290 17.5 0.70 61 666 *Not to be used for new designs w w w.mechatronic s.com 10.03.17 E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 Cooling Simplified
LPC15P12-BTER 价格&库存
很抱歉,暂时无法提供与“LPC15P12-BTER”相匹配的价格&库存,您可以联系我们找货
