UF90DPB12-H1S2A
UF90DPB12-H1S2A
    MECHATRONICSFANGROUP(机电一体化)
    BLOWER 120X37MM 115VAC
UF90DPB12-H1S2A 数据手册
0.62 (15.8) AIR OUT 1.22 (31) 0.60 0.24 (6) M4 AIR IN AIR OUT M4 AIR IN 9 .3 ±0 0) 1 1 .8 0 ± 11 (30 (120 x 120 x 37 mm) 4.72 x 4.72 x 1.46 inches Features: STATIC PRESSURE - IN. OF WATER Rotation 2.65 (67.4) AC BLOWERS UF90DPB series H 0.50 0.40 0.30 0.20 0.10 0.08 (2) 0 5.0 10.0 15.0 25.0 20.0 AIR FLOW (CFM) 1.47 ±0.02 (37.2 ±0.5) UL 1332 26AWG single inlet blower Operating voltage: 115 or 230 VAC Operating temp. -40° ~ 60°C Construction: aluminum die cast motor base; UL94V-0 reinforced nylon impeller Bearing option: ball bearing Motor: shaded pole Air Flow: centrifugal Connection: UL1332 26AWG lead wires Protection: impedance w w w.mechatronic s.com 10.19.21 Model No. Rated Freq. Input Rated Locked Speed Voltage Power Cur. Cur. Air Volume V HZ W A A MM INCH dbA kg UF90DPB12-H1S2A 115 60 18 0.21 0.26 2,700 0.60 21 13 0.50 51 0.66 UF90DPB23-H1S2A 230 60 18 0.10 0.12 2,700 0.60 21 13 0.50 51 0.66 E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 RPM M³/Min. CFM Max. Static Sound Weight Pressure (H2 0) Noise 800-453-4569 Cooling Simplified
UF90DPB12-H1S2A 价格&库存
很抱歉,暂时无法提供与“UF90DPB12-H1S2A”相匹配的价格&库存,您可以联系我们找货
