08038PB (80 X 38L)
Legacy Part No. 3115PS
NMBTC.COM / 248.919.2250
Characteristic Curves
Motor Structure: Shaded Pole Induction Motor
Motor Protection: Impedance Protection
Insulation Resistance:
10M Ω or over with a DC500V Megger
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
Ps
(Pa)
.24
60
.16
40
.08
Expected Life
25°C
K
J
7
100,000 Hours
Material
Casing
Impeller
Bearing
Lead Wire
or Terminal
60Hz
50Hz
L
Failure Rate: 10%
0.6
0.8
1.0 (m3/min)
14 21
Air Flow
28
35 CFM
0.4
Outline
: Aluminum (Black Painting)
: Plastic (Black) UL94V-0
: Ball Bearing
: AWG22, UL3266
: Faston #110 or equivalent
.169
8 – (φ4.3 ± 0.2)
AIR
(3.4)
Panel Cut-Outs
inch
Units: (mm)
2.815
(71.5)
φ
(φ 3.4
88 6
.0
.169
4 – (φ4.3)
3.03
(77)
AC Axial Fans
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
In H2O
Static Pressure
General Specifications
2.815
(71.5)
3.03
(77)
INLET SIDE / OUTLET SIDE
ROTATION
NAME PLATE
Flange Type
08038PB (80 X 38L)
Specifications
MODEL
LEGACY P/N
Rated Frequency Starting Current Input Speed
Voltage
Voltage
Power
(V)
(W) (min-1)*2 CFM*1 (m3/min)*2 in H2O
Noise
Mass
(Pa)*2 (dB)*2
(g)
270
(Hz)
(V)
(A)*1
100
08038PB-A0J-EA-00
3115PS-10T-B10-B00
100
50
65
0.065
4.5
1700
17.6
0.50
.06
16.6
23.0
60
65
0.055
4.0
1900
19.4
0.55
.08
21.5
25.0
270
08038PB-A0K-EA-00
3115PS-10T-B20-B00
100
50
65
0.080
4.5
2100
21.0
0.60
.10
24.5
29.0
270
100
60
65
0.070
4.0
2300
24.0
0.68
.12
29.4
32.0
270
08038PB-A0L-EA-00
3115PS-10T-B30-B00
100
50
65
0.170
9.0
2700
26.5
0.75
.14
34.3
33.0
270
100
60
65
0.120
7.0
3200
32.0
0.90
.20
49.0
38.0
270
08038PB-A1J-EA-00
3115PS-12T-B10-A00
115
50
75
0.060
4.5
1700
17.6
0.50
.06
16.6
23.0
270
115
60
75
0.055
4.0
1900
19.4
0.55
.08
21.5
25.0
270
08038PB-A1K-EA-00
3115PS-12T-B20-A00
115
50
75
0.080
5.0
2100
21.0
0.60
.10
24.5
29.0
270
115
60
75
0.070
4.5
2300
24.0
0.68
.12
29.4
32.0
270
115
08038PB-A1L-EA-00
3115PS-12T-B30-A00
115
50
75
0.140
9.0
2700
26.5
0.75
.14
34.3
33.0
270
60
75
0.110
7.0
3200
32.0
0.90
.20
49.0
38.0
270
200
08038PB-B0J-EA-00
3115PS-20T-B10-B00
200
50
130
0.045
4.5
1700
17.6
0.50
.06
16.6
23.0
270
60
160
0.040
4.0
1900
19.4
0.55
.08
21.5
26.0
270
200
08038PB-B0K-EA-00
3115PS-20T-B20-B00
200
50
130
0.040
4.5
2100
21.0
0.60
.10
24.5
29.0
270
60
160
0.035
4.0
2300
24.0
0.68
.13
31.3
32.0
270
200
08038PB-B0L-EA-00
3115PS-20T-B30-B00
200
50
130
0.080
9.0
2700
26.5
0.75
.14
34.3
33.0
270
60
130
0.060
7.0
3200
32.0
0.90
.20
49.0
38.0
270
220
08038PB-B2J-EA-00
3115PS-22T-B10-B00
220
50
150
0.050
5.5
1750
17.6
0.50
.06
16.6
23.0
270
60
150
0.045
4.5
2000
21.2
0.60
.09
23.5
26.0
270
220
08038PB-B2K-EA-00
3115PS-22T-B20-B00
220
50
165
0.045
6.0
2200
22.0
0.63
.10
24.5
29.0
270
60
165
0.040
5.0
2400
25.4
0.72
.13
31.3
34.0
270
220
08038PB-B2L-EA-00
3115PS-22T-B30-B00
220
50
150
0.070
9.0
2700
26.5
0.75
.14
34.3
33.0
270
60
150
0.060
7.0
3200
32.0
0.90
.20
49.0
38.0
270
230
08038PB-B3J-EA-00
3115PS-23T-B10-A00
230
50
150
0.055
6.0
1800
17.6
0.50
.07
17.6
23.0
270
60
150
0.050
5.0
2100
22.0
0.63
.10
24.5
26.0
270
230
08038PB-B3K-EA-00
3115PS-23T-B20-A00
230
50
150
0.050
7.0
2200
22.0
0.63
.10
24.5
30.0
270
60
150
0.045
6.0
2500
26.0
0.74
.14
35.2
34.0
270
230
08038PB-B3L-EA-00
3115PS-23T-B30-A00
230
50
150
0.070
10.0
2700
26.5
0.75
.14
34.3
33.0
270
60
150
0.055
8.0
3200
32.0
0.90
.20
49.0
38.0
270
240
08038PB-B4J-EA-00
3115PS-24T-B10-A00
240
50
150
0.060
7.0
1800
17.6
0.50
.07
17.6
23.0
270
60
150
0.055
6.0
2150
21.6
0.64
.10
25.4
26.0
270
240
08038PB-B4K-EA-00
3115PS-24T-B20-A00
240
50
150
0.055
7.0
2200
22.0
0.63
.10
24.5
30.0
270
60
150
0.045
6.0
2600
26.5
0.75
.15
37.2
35.0
270
240
08038PB-B4L-EA-00
3115PS-24T-B30-A00
240
50
150
0.075
12.0
2700
26.5
0.75
.14
34.3
33.0
270
60
150
0.060
9.0
3200
32.0
0.90
.20
49.0
38.0
270
Rotation: Counterclockwise
Contact NMB for Availability
Airflow Outlet: Air Out Over Struts
*1: Maximum Values in Free Air
*2: Average Values in Free Air
*3: Minimum Values in Free Air
DC
AC Axial Fans
Max.
Max. Static
Air Flow Pressure
很抱歉,暂时无法提供与“3115PS-23W-B20-A00”相匹配的价格&库存,您可以联系我们找货
