09225PB (92 X 25L)
Legacy Part No. 3610PS
NMBTC.COM / 818.341.3355
Characteristic Curves
Motor Structure: Shaded Pole Induction Motor
Motor Protection: Impedance Protection
Insulation Resistance:
10M Ω or over with a DC500V Megger
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
.24
(Pa)
40
.08
Ps
K
M
0 0.2 0.4 0.6 0.8 1.0
Failure Rate: 10%
25°C 100,000 Hours
7
14 21
28
35
(m3/min)
CFM
Air Flow
Outline
: Aluminum (Black Painting)
: Plastic (Black) UL94V-0
: Ball Bearing
: AWG22, UL3266
: Faston #110 or equivalent
ROTATION
.125 ± .02
(3.5)
Panel Cut-Outs
.98 +.04
–.01
(25 +1 )
–0.3
inch
Units: (mm)
3.25
(82.5)
φ
(φ 4.1
10 7
6)
.169
4 – (φ4.3)
3.25
(82.5)
3.55
(89)
INLET SIDE / OUTLET SIDE
.125 ± .02
(3.5)
NAME PLATE
3.25 ± .01
(82.5 ± 0.3)
3.62 ± .02
(92.5)
3.62 ± .02
(92.5)
AIR
3.25 ± .01
(82.5 ± 0.3)
Material
Casing
Impeller
Bearing
Lead Wire
or Terminal
60Hz
50Hz
L
60
.16
Expected Life
3.55
(89)
AC Axial Fans
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
In H2O
.32
Static Pressure
General Specifications
.169
6 – (φ4.3 ± 0.2)
Flange Type
09225PB (92 X 25L)
Rated Frequency Starting Current Input Speed
Voltage
Voltage
Power
Max.
Max. Static Noise
Air Flow Pressure
Mass
(W) (min-1)*2 CFM*1 (m3/min)*2 in H2O (Pa)*2 (dB)*2
(g)
Specifications
MODEL
LEGACY P/N
(V)
(Hz)
(V)
(A)*1
100
09225PB-A0J-EA-00
3610PS-10T-B10-B00
100
50
65
0.100
7.0
1450
16.0
0.46
.05
13.7
23.0
60
65
0.090
6.0
1800
20.0
0.58
.08
19.6
26.0
300
09225PB-A0K-EA-00
3610PS-10T-B20-B00
100
50
65
0.095
7.0
2100
21.0
0.60
.11
27.4
30.0
300
100
60
65
0.085
6.0
2500
28.0
0.80
.16
39.2
35.0
300
09225PB-A0L-EA-00
3610PS-10T-B30-B00
100
50
65
0.190
13.0
2600
28.0
0.80
.17
43.1
33.5
300
100
60
65
0.150
10.0
3100
34.5
0.98
.24
60.7
38.0
300
0 9225PB-A1J-EA-00 3610PS-12T-B10-A00
115
50
75
0.090
7.0
1450
16.0
0.46
.05
13.7
22.0
300
115
60
75
0.080
6.0
1800
20.0
0.58
.08
19.6
25.0
300
09225PB-A1K-EA-00
3610PS-12T-B20-A00
115
50
75
0.095
7.0
2100
21.0
0.60
.12
29.4
30.0
300
115
60
75
0.090
6.0
2500
28.0
0.80
.16
39.2
35.0
300
115
09225PB-A1L-EA-00
3610PS-12T-B30-A00
115
50
75
0.170
12.0
2600
28.0
0.80
.17
43.1
33.5
300
60
75
0.130
9.0
3100
34.5
0.98
.24
60.7
38.0
300
200
09225PB-B0J-EA-00
3610PS-20T-B10-B00
200
50
130
0.045
7.0
1500
16.0
0.46
.05
13.7
24.0
300
60
130
0.040
6.0
1900
21.0
0.60
.08
19.6
27.0
300
200
09225PB-B0K-EA-00
3610PS-20T-B20-B00
200
50
130
0.060
7.0
2100
22.9
0.65
.11
27.4
30.0
300
60
160
0.050
6.0
2500
28.0
0.80
.16
39.0
35.0
300
200
09225PB-B0L-EA-00
3610PS-20T-B30-B00
200
50
130
0.100
13.0
2600
28.0
0.80
.17
43.1
33.5
300
60
130
0.080
10.0
3100
34.5
0.98
.24
60.7
38.0
300
220
09225PB-B2J-EA-00
3610PS-22T-B10-B00
220
50
165
0.050
8.0
1450
16.0
0.46
.05
13.7
23.0
300
60
165
0.040
7.0
1800
21.0
0.60
.08
19.6
26.0
300
220
09225PB-B2K-EA-00
3610PS-22T-B20-B00
220
50
165
0.050
6.5
2100
21.0
0.60
.12
29.4
30.0
300
60
165
0.050
5.5
2500
28.0
0.80
.15
38.2
35.0
300
220
09225PB-B2L-EA-00
3610PS-22T-B30-B00
220
50
165
0.100
13.0
2600
28.0
0.80
.17
43.1
34.0
300
60
165
0.080
10.0
3100
34.5
0.98
.24
60.7
39.0
300
230
09225PB-B3J-EA-00
3610PS-23T-B10-A00
230
50
180
0.050
7.0
1450
16.0
0.46
.05
13.7
22.0
300
60
180
0.040
6.0
1800
20.0
0.58
.08
19.6
26.0
300
230
09225PB-B3K-EA-00
3610PS-23T-B20-A00
230
50
180
0.050
7.0
2100
21.0
0.60
.12
29.4
30.0
300
60
180
0.050
6.0
2500
28.0
0.80
.16
39.2
35.0
300
230
09225PB-B3L-EA-00
3610PS-23T-B30-A00
230
50
180
0.090
13.0
2600
28.0
0.80
.17
43.1
34.0
300
60
180
0.070
10.0
3100
34.5
0.98
.24
60.7
39.0
300
240
09225PB-B4J-EA-00
3610PS-24T-B10-A00
240
50
180
0.050
8.0
1450
16.0
0.46
.05
13.7
24.0
300
60
180
0.045
7.0
1800
21.0
0.60
.08
19.6
27.0
300
240
09225PB-B4K-EA-00
3610PS-24T-B20-A00
240
50
180
0.050
9.0
2100
21.0
0.60
.12
29.4
30.0
300
60
180
0.050
8.0
2500
28.0
0.80
.16
39.2
35.0
300
240
09225PB-B4L-EA-00
3610PS-24T-B30-A00
240
50
180
0.085
13.0
2600
28.0
0.80
.17
43.1
34.0
300
60
180
0.065
10.0
3100
34.5
0.98
.24
60.7
39.0
300
*1: Maximum Values in Free Air
*2: Average Values in Free Air
*3: Minimum Values in Free Air
DC
AC Axial Fans
Rotation: Counterclockwise
Airflow Outlet: Air Out Over Struts
Contact NMB for Availability
300
很抱歉,暂时无法提供与“3610PS-12T-B10-A00”相匹配的价格&库存,您可以联系我们找货
