11938TB (119 X 38L)
Legacy Part No. 4715TS Metal Blades/Potting
NMBTC.COM / 818.341.3355
Characteristic Curves
General Specifications
In H2O
Motor Structure: Shaded Pole Induction Motor
Motor Protection: Impedance Protection
Insulation Resistance:
.48
.40
10M Ω or over with a DC500V Megger
.32
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
.24
-10°C ~ +60°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
.16
.08
AC Axial Fans
Expected Life
(m3 /min)
Failure Rate: 10%
25°C
90,000 Hours
35
106
141 CFM
Outline
Material
Casing
Impeller
Bearing
Lead Wire
or Terminal
70
: Aluminum (Black Painting)
: Steel
: Ball Bearings
: AWG22, UL3266
: Faston #110 or equivalent
ROTATION
3.11
(7.9)
.169
8 – ( 4.3)
Panel Cut-Outs
inch
Units: (mm)
4.13
(105 0.3 )
4.69
(119 0.5 )
4.13
(105)
5.
3
13 5
6)
(115)
4.53
.169
4 – ( 4.3)
4.13
(105)
4.53
(115)
4.13
(105 0.3 )
4.69
(119 0.5 )
1.49
(38 0.5 )
INLET SIDE / OUTLET SIDE
Specifications
MODEL
Rated Frequency Starting Current Input Speed
Voltage
Voltage
Power
LEGACY P/N
(V)
(Hz)
(V) (A)*1
(W) (min-1)*2 CFM*1 (m3/min)*2 in H2O
100
50
65 0.450
20.0
2600
98.84
2.80
100
60
65 0.340
17.0
3100 116.49
3.30
115
50
75 0.390
21.0
2600
98.84
2.80
115
60
75 0.300
17.0
3100 116.49
200
50
130 0.220
21.0
2600
200
60
130 0.170
17.0
220
50
145 0.200
20.0
2600
220
60
145 0.150
17.0
3100 116.49
230
50
175 0.190
21.0
2600
11938TB-A0N-QA-00 4715TS-10T-B50-BM0
11938TB-A1N-QA-00 4715TS-12T-B50-AM0
11938TB-B3N-QA-00 4715TS-23T-B50-AM0
11938TB-B0N-QA-00 4715TS-20T-B50-BM0
11938TB-B2N-QA-00 4715TS-22T-B50-BM0
11938TB-B4N-QA-00 4715TS-24T-B50-AM0
Rotation: Counterclockwise
Contact NMB for Availability
Max. Max. Static
Air Flow Pressure
Noise Mass
(Pa)*2 (dB)*2
(g)
0.352
88.0
46
650
0.400
100.0
50
650
0.352
88.0
46
650
3.30
0.400
100.0
50
650
98.84
2.80
0.352
88.0
46
650
3100 116.49
3.30
0.400
100.0
50
650
2.80
0.352
88.0
46
650
3.30
0.400
100.0
50
650
2.80
0.352
88.0
46
650
98.84
98.84
230
60
175 0.140
17.0
3100 116.49
3.30
0.400
100.0
50
650
240
50
175 0.180
20.0
2600
98.84
2.80
0.352
88.0
46
650
240
60
175 0.140
17.0
3100 116.49
3.30
0.400
100.0
50
650
Airflow Outlet: Air Out Over Struts
*1: Maximum Values in Free Air
*2: Average Values in Free Air
*3: Minimum Values in Free Air
很抱歉,暂时无法提供与“4715TS-12T-B50-AM0”相匹配的价格&库存,您可以联系我们找货
