LPC135A23-BTHR
LPC135A23-BTHR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL135X38MM230VACEC
LPC135A23-BTHR 数据手册
AC AXIAL FANS AC AXIAL FANS [ PART NUMBERING SYSTEM ] UF 12 A R 12 - B T H NS R - _ AC SERIES CC ............. Conformal Coating F ................ High Temperature B1............... Tachometer Output B2.............. Locked Rotor Output 2EM........... IP68 EX.............. ATEX Rated UF, UM, UX, LPT, LPH, ... etc. FRAME SIZE 60.............. 60mm 80.............. 80mm 92 ............. 92mm 12 .............. 120mm 13 .............. 127mm 16 .............. 160mm 15 .............. 172x150mm 17 .............. 172mm dia. 18 .............. 180mm 20 ............. 205mm 25 ............. 254mm dia. ROHS COMPLIANT OPTIONS N ............... IP55 NS ����������� IP55 & Salt Fog Protection AIR FLOW LEVEL FRAME THICKNESS SL S L M H A ............... 38mm B ............... 25mm D ............... 30mm F ............... 62mm G ............... 89mm H ............... 107mm J ................ 90mm K ............... 55mm P ............... 51mm E CONNECTION T ................ Terminal FEATURES W .............. Leadwire C ............... Permanent Split Capacitor Motor M .............. Metal Impeller CR ............. Permanent Split Capacitor & Reverse Flow R ............... Reverse Airflow E ............... Frameless Motor MR ........... Metal Impeller & Reverse Flow BEARINGS B ............... Ball S ............... Sleeve VOLTAGE 12 ............. 115 VAC 23 ............ 230 VAC 12/23 ........ 115/230 VAC Dual Voltage 99 ............ 90 ~ 264 VAC 02 ������������ 24 VAC w w w.mechatronic s.com 12.20.19 E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 Cooling Simplified
LPC135A23-BTHR 价格&库存
很抱歉,暂时无法提供与“LPC135A23-BTHR”相匹配的价格&库存,您可以联系我们找货
