6.77 ±0.02
(172 ±0.5)
6.38 ±0.01
(162 ±0.3)
2.17 ±0.02
(55 ±0.5)
ø5.75
(ø146)
Ø5.91 ±0.02
(Ø150±0.5)
ø0.16 ±0.01
(ø4.2 ±0.2)
14.96
(350)
5˚
55.
.91
(23)
6.77 x 5.91 x 2.17 inches
1.69
(43)
aluminum die cast frame;
UL94V-0 PBT impeller
Bearing option:
ball bearing
Motor:
permanent split capacitor
Air Flow:
exhaust over struts
Connection:
terminal or 22 AWG lead wire
Protection:
thermal
Option:
dual voltage 115/130VAC; IP55;
IP55 + salt fog
w w w.mechatronic s.com
11.23.20
H
.80
.60
.40
.20
50
100
LEAD WIRE TYPE
0.12
(3)
1.50
(38)
200
250
TERMINAL TYPE
Rated Freq. Input Rated Locked Speed
Voltage
Power Cur.
Cur.
Air Volume
V
HZ
W
A
A
RPM
MM
INCH
dbA
kg
115
60
38
0.34
0.76
3,400
8.3
293
23
0.90
60
1.05
UF15KC23 -__H
230
60
38
0.17
0.38
3,400
8.3
293
23
0.90
60
1.05
Fa x : 425 -2 2 2- 515 5
Tel: 425 -2 2 2- 5 9 0 0
M³/Min. CFM
Max. Static Sound Weight
Pressure (H2 0) Noise
UF15KC12 -__H
E - mail: S ales @ M echatronic s.com
300
0.31
(8)
t=0.5
Model No.
150
AIR FLOW (CFM)
Operating voltage: 115 or 230 VAC
Construction:
1.00
(20)
(172 x 150 x 55 mm)
1.20
STATIC PRESSURE - IN. OF WATER
AC AXIAL FANS
UF15KC series
800-453-4569
Cooling Simplified
很抱歉,暂时无法提供与“UF15KC23-BTHNSR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+869.384121+112.53272
