3610PS-10T-B30-B00
3610PS-10T-B30-B00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 92.5X25MM 100VAC TERM
3610PS-10T-B30-B00 数据手册
09225PB (92 X 25L) Legacy Part No. 3610PS NMBTC.COM / 818.341.3355 Characteristic Curves Motor Structure: Shaded Pole Induction Motor Motor Protection: Impedance Protection Insulation Resistance: 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: .24 (Pa) 40 .08 20 Ps K M 0 0.2 0.4 0.6 0.8 1.0 Failure Rate: 10% 25°C 100,000 Hours 7 14 21 28 35 (m3/min) CFM Air Flow Outline : Aluminum (Black Painting) : Plastic (Black) UL94V-0 : Ball Bearing : AWG22, UL3266 : Faston #110 or equivalent ROTATION .125 ± .02 (3.5) Panel Cut-Outs .98 +.04 –.01 (25 +1 ) –0.3 inch Units: (mm) 3.25 (82.5) φ (φ 4.1 10 7 6) .169 4 – (φ4.3) 3.25 (82.5) 3.55 (89) INLET SIDE / OUTLET SIDE .125 ± .02 (3.5) NAME PLATE 3.25 ± .01 (82.5 ± 0.3) 3.62 ± .02 (92.5) 3.62 ± .02 (92.5) AIR 3.25 ± .01 (82.5 ± 0.3) Material Casing Impeller Bearing Lead Wire or Terminal 60Hz 50Hz L 60 .16 Expected Life 3.55 (89) AC Axial Fans -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) In H2O .32 Static Pressure General Specifications .169 6 – (φ4.3 ± 0.2) Flange Type 09225PB (92 X 25L) NMBTC.COM / 818.341.3355 Legacy Part No. 3610PS Rated Frequency Starting Current Input Speed Voltage Voltage Power Max. Max. Static Noise Air Flow Pressure Mass (W) (min-1)*2 CFM*1 (m3/min)*2 in H2O (Pa)*2 (dB)*2 (g) Specifications MODEL LEGACY P/N (V) (Hz) (V) (A)*1 ** 100 09225PB-A0J-EA-00 3610PS-10T-B10-B00 100 50 65 0.100 7.0 1450 16.0 0.46 .05 13.7 23.0 60 65 0.090 6.0 1800 20.0 0.58 .08 19.6 26.0 300 ** 09225PB-A0K-EA-00 3610PS-10T-B20-B00 100 50 65 0.095 7.0 2100 21.0 0.60 .11 27.4 30.0 300 100 60 65 0.085 6.0 2500 28.0 0.80 .16 39.2 35.0 300 ** 09225PB-A0L-EA-00 3610PS-10T-B30-B00 100 50 65 0.190 13.0 2600 28.0 0.80 .17 43.1 33.5 300 100 60 65 0.150 10.0 3100 34.5 0.98 .24 60.7 38.0 300 0 9225PB-A1J-EA-00 3610PS-12T-B10-A00 115 50 75 0.090 7.0 1450 16.0 0.46 .05 13.7 22.0 300 115 60 75 0.080 6.0 1800 20.0 0.58 .08 19.6 25.0 300 09225PB-A1K-EA-00 3610PS-12T-B20-A00 115 50 75 0.095 7.0 2100 21.0 0.60 .12 29.4 30.0 300 115 60 75 0.090 6.0 2500 28.0 0.80 .16 39.2 35.0 300 115 09225PB-A1L-EA-00 3610PS-12T-B30-A00 115 50 75 0.170 12.0 2600 28.0 0.80 .17 43.1 33.5 300 60 75 0.130 9.0 3100 34.5 0.98 .24 60.7 38.0 300 ** 200 09225PB-B0J-EA-00 3610PS-20T-B10-B00 200 50 130 0.045 7.0 1500 16.0 0.46 .05 13.7 24.0 300 60 130 0.040 6.0 1900 21.0 0.60 .08 19.6 27.0 300 ** 200 09225PB-B0K-EA-00 3610PS-20T-B20-B00 200 50 130 0.060 7.0 2100 22.9 0.65 .11 27.4 30.0 300 60 160 0.050 6.0 2500 28.0 0.80 .16 39.0 35.0 300 ** 200 09225PB-B0L-EA-00 3610PS-20T-B30-B00 200 50 130 0.100 13.0 2600 28.0 0.80 .17 43.1 33.5 300 60 130 0.080 10.0 3100 34.5 0.98 .24 60.7 38.0 300 ** 220 09225PB-B2J-EA-00 3610PS-22T-B10-B00 220 50 165 0.050 8.0 1450 16.0 0.46 .05 13.7 23.0 300 60 165 0.040 7.0 1800 21.0 0.60 .08 19.6 26.0 300 ** 220 09225PB-B2K-EA-00 3610PS-22T-B20-B00 220 50 165 0.050 6.5 2100 21.0 0.60 .12 29.4 30.0 300 60 165 0.050 5.5 2500 28.0 0.80 .15 38.2 35.0 300 ** 220 09225PB-B2L-EA-00 3610PS-22T-B30-B00 220 50 165 0.100 13.0 2600 28.0 0.80 .17 43.1 34.0 300 60 165 0.080 10.0 3100 34.5 0.98 .24 60.7 39.0 300 230 09225PB-B3J-EA-00 3610PS-23T-B10-A00 230 50 180 0.050 7.0 1450 16.0 0.46 .05 13.7 22.0 300 60 180 0.040 6.0 1800 20.0 0.58 .08 19.6 26.0 300 230 09225PB-B3K-EA-00 3610PS-23T-B20-A00 230 50 180 0.050 7.0 2100 21.0 0.60 .12 29.4 30.0 300 60 180 0.050 6.0 2500 28.0 0.80 .16 39.2 35.0 300 230 09225PB-B3L-EA-00 3610PS-23T-B30-A00 230 50 180 0.090 13.0 2600 28.0 0.80 .17 43.1 34.0 300 60 180 0.070 10.0 3100 34.5 0.98 .24 60.7 39.0 300 ** 240 09225PB-B4J-EA-00 3610PS-24T-B10-A00 240 50 180 0.050 8.0 1450 16.0 0.46 .05 13.7 24.0 300 60 180 0.045 7.0 1800 21.0 0.60 .08 19.6 27.0 300 ** 240 09225PB-B4K-EA-00 3610PS-24T-B20-A00 240 50 180 0.050 9.0 2100 21.0 0.60 .12 29.4 30.0 300 60 180 0.050 8.0 2500 28.0 0.80 .16 39.2 35.0 300 ** 240 09225PB-B4L-EA-00 3610PS-24T-B30-A00 240 50 180 0.085 13.0 2600 28.0 0.80 .17 43.1 34.0 300 60 180 0.065 10.0 3100 34.5 0.98 .24 60.7 39.0 300 *1: Maximum Values in Free Air *2: Average Values in Free Air *3: Minimum Values in Free Air DC AC Axial Fans Rotation: Counterclockwise Airflow Outlet: Air Out Over Struts Contact NMB for Availability ** 300
3610PS-10T-B30-B00 价格&库存
很抱歉,暂时无法提供与“3610PS-10T-B30-B00”相匹配的价格&库存,您可以联系我们找货
