3.5 ±0.02
(89 ±0.5)
ø0.18 ±0.01
(ø4.6 ±0.2)
ø8.6 6
(ø220)
0.9
0.10
(2.5)
ø9.6 9
(ø246)
STATIC PRESSURE - IN. OF WATER
AC AXIAL FANS
UF25GC series
ø10.0 ±0.03
(ø254 +1.0
– 0.5 )
0.8
0.7
1
2
0.6
3
0.5
0.4
0.3
0.2
0.1
100 200 300 400 500 600 700 800 900
AIR FLOW (CFM)
(254 dia. x 89 mm)
0.12
(3)
10.0 dia. x 3.5 inches
Construction:
aluminum die cast frame;
UL94V-0 PBT impeller
Model No.
TERMINAL TYPE
Rated Freq. Input Rated Locked Speed Air Volume Max. Static Sound Weight
Pressure (H2 0) Noise
Voltage
Power Cur.
Cur.
Curve
M³/Min.
CFM
MM INCH dbA
V
HZ
W
A
A
RPM
kg
Bearing option:
ball bearing
Motor:
permanent split capacitor
UF25GC12-_ _H
115
60
33
0.29
0.51
1,650
15.5
550
10
0.40
55
1.90
1
Air Flow:
exhaust over struts
UF25GC23-_ _H
230
60
33
0.14
0.25
1,650
15.5
550
10
0.40
55
1.90
1
Connection:
terminal or 22 AWG lead wires
UF25GCA12-_ _H
115
60
75
0.66
0.70
2,600
19.3
680
9.4
0.37
62
1.90
2
Protection:
thermal
UF25GCA23-_ _H
230
60
75
0.35
0.36
2,600
19.3
680
9.4
0.37
62
1.90
2
UF25GCB12-_ _H
115
60
96
0.88
1.16
3200
23.0
812
20.7
0.82
65
2.30
3
Option:
dual voltage 115/230VAC
UF25GCB23-_ _H
230
60
98
0.45
0.60
3200
23.0
812
20.7
0.82
65
2.30
3
w w w.mechatronic s.com
12.30.19
t=0.5
0.31
(8)
Operating voltage: 115 or 230 VAC
LEAD WIRE TYPE
E - mail: S ales @ M echatronic s.com
Fa x : 425 -2 2 2- 515 5
Tel: 425 -2 2 2- 5 9 0 0
800-453-4569
Cooling Simplified
很抱歉,暂时无法提供与“UF25GC23-BWHNSR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1280.573101+165.87901
- 10+1035.2661110+134.10317
- 30+929.3759130+120.38669
- 50+883.4873150+114.44251
- 100+874.18774100+113.23789
