3115FS-12W-B20-A00
3115FS-12W-B20-A00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 80X38MM 115VAC WIRE
3115FS-12W-B20-A00 数据手册
08038FB (80 X 38L) NMBTC.COM / 248.919.2250 Legacy Part No. 3115FS General Specifications Motor Structure: Shaded Pole Induction Motor Motor Protection: Impedance Protection Insulation Resistance: In H2O (Pa) 55 .18 45 L .14 35 K .10 25 H Ps .06 15 .02 5 Static Pressure 10M Ω or over with a DC500V Megger .22 Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Failure Rate: 10% 25°C 4 50,000 Hours 8 12 16 20 24 28 32 36 Air Flow CFM Outline Material Casing Impeller Bearing Lead Wire or Terminal (m3/min) .11 .22 .34 .45 .56 .65 .79 .90 1.0 : Aluminum : UL94V-O Reinforced Plastic : Ball Bearing : AWG22, UL3266 : Faston #110 or equivalent ROTATION AIR NAME PLATE Panel Cut-Outs inch Units: (mm) Flange Type (3.4) 2.815 (71.5) φ (φ 3.4 88 6 .0 ) 3.03 (77) .169 4 – (φ4.3) 2.815 (71.5) 3.03 (77) INLET SIDE / OUTLET SIDE Specifications MODEL Rated Frequency Starting Current Input Speed Voltage Voltage Power LEGACY P/N (V) (Hz) 08038FB-A1H-EA-00 3115FS-12T-B00-A00 115 60 75 0.045 4.0 1850 18.0 0.51 3115FS-12T-B10-A00 115 60 75 0.087 6.5 2100 22.0 0.62 08038FB-A1K-EA-00 3115FS-12T-B20-A00 115 60 75 0.090 7.5 2700 27.0 0.76 08038FB-A1L-EA-00 3115FS-12T-B30-A00 115 60 75 0.100 8.5 3250 32.0 0.90 08038FB-A1J-EA-00 08038FB-B3J-EA-00 3115FS-23T-B10-A00 230 (V) (A)*1 Max. Max. Static Air Flow Pressure (W) (min-1)*2 CFM*1 (m3/min)*2 in H2O Noise Mass (Pa)*2 (dB)*2 (g) .07 17.5 31 340 .09 22.5 36 340 .13 32.5 40 340 .18 45.0 44 340 60 175 0.050 6.5 2050 20.0 0.57 .09 22.5 35 340 08038FB-B3K-EA-00 3115FS-23T-B20-A00 230 60 175 0.060 7.5 2750 28.0 0.79 .13 32.5 40 340 08038FB-B3L-EA-00 3115FS-23T-B30-A00 230 60 175 0.065 8.0 3250 33.0 0.93 .18 45.0 44 340 Rotation: Counterclockwise Airflow Outlet: Air In Over Struts *1: Maximum Values in Free Air *2: Average Values in Free Air *3: Minimum Values in Free Air DC AC Axial Fans Expected Life J
3115FS-12W-B20-A00 价格&库存
很抱歉,暂时无法提供与“3115FS-12W-B20-A00”相匹配的价格&库存,您可以联系我们找货
