3110SB-04W-B50-E00
3110SB-04W-B50-E00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 80X25MM 12VDC WIRE
3110SB-04W-B50-E00 数据手册
08025SA (80 X 25L) Legacy Part No. 3110SB NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: P-Q Curve Auto Restart/Polarity Protection In H2O (Pa) Insulation Resistance: 0.14 35.0 0.12 Speed Curve 4000 3500 Ps Expected Life 40,000 Hours (AA/EA) 3000 M 0.10 25.0 0.08 20.0 0.06 15.0 0.04 Failure Rate: 10% 30.0 5.0 0.00 0.0 1000 L K 0.0 500 0.5 5.0 10.0 15.0 0 1.0 20.0 25.0 30.0 35.0 40.0 45.0 (m3/min) CFM Air Flow Outline 11.8 min (300) Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL3385, AWG26, +Red, -Black 1500 N 0.0 Material 2000 M 10.0 0.02 2500 L K Speed -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) 60°C 40.0 N Static Pressure DC Axial Fans 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: 0.16 0.169 (4−φ4.3± 0.2) ROTATION 34 ) 3. 5.0 8 ( 38 ) 3. 6.0 8 ( 2.81 (71.5± 0.3) .169 (4 – φ4.3) AIR NAME PLATE 2.81 (71.5) 3.02 (76.8) .169 (4 – φ4.3) 2.81 (71.5) 3.02 (76.8) inch Units: (mm) 3.15 (80.0± 0.5) Panel Cut-Outs 2.81 (71.5± 0.3) 3.15 (80.0 ± 0.5) 2.81 (71.5) 3.02 (76.8) 2.81 (71.5) 3.02 (76.8) INLET SIDE OUTLET SIDE .157 (4.0) .157 0.98 (4.0) (25.0± 0.5) Specifications Rated MODEL Voltage Operating Current Voltage Input Speed Power Max. Max. Static Air Flow Pressure Noise Mass (V) (V) (A)*1 (W)*1 (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 08025SA-12K-AA-00 3110SB-04W-B20-B00 12 6 ~ 13.8 0.05 0.60 2000 26.1 0.74 0.07 16.5 19.0 80 3110SB-04W-B30-B00 12 6 ~ 13.8 0.06 0.72 2300 30.4 0.86 0.09 21.5 22.0 80 08025SA-12M-AA-00 3110SB-04W-B40-B00 12 6 ~ 13.8 0.09 1.08 2700 36.0 1.02 0.12 29.0 26.0 80 08025SA-12N-AA-00 3110SB-04W-B50-B00 12 6 ~ 13.8 0.14 1.68 3100 41.3 1.17 0.15 37.5 30.0 80 08025SA-12R-AA-00 3110SB-04W-B80-B00 12 7.0 ~ 13.8 0.32 3.84 4500 60.0 1.70 0.33 82.0 42.0 80 08025SA-24K-AA-00 3110SB-05W-B20-B00 24 12.0 ~ 27.6 0.03 0.72 2000 26.1 0.74 0.07 16.5 19.0 80 08025SA-24L-AA-00 3110SB-05W-B30-B00 24 12.0 ~ 27.6 0.04 0.96 2300 30.4 0.86 0.09 21.5 22.0 80 08025SA-24M-AA-00 3110SB-05W-B40-B00 24 12.0 ~ 27.6 0.06 1.44 2700 36.0 1.02 0.12 29.0 26.0 80 08025SA-24N-AA-00 3110SB-05W-B50-B00 24 12.0 ~ 27.6 0.08 1.92 3100 41.3 1.17 0.15 37.5 30.0 80 08025SA-24R-EA-00 3110SB-05W-B80-B00 24 12.0 ~ 26.4 0.17 4.08 4500 60.0 1.70 0.33 82.0 42.0 80 08025SA-12L-AA-00 11 LEGACY P/N Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available
3110SB-04W-B50-E00 价格&库存
很抱歉,暂时无法提供与“3110SB-04W-B50-E00”相匹配的价格&库存,您可以联系我们找货
