2406KL-04W-B50-L00
2406KL-04W-B50-L00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 60X15MM 12VDC WIRE
2406KL-04W-B50-L00 数据手册
06015KA (60 X 15L) Legacy Part No. 2406KL NMBTC.COM / 818.341.3355 Characteristic Curves General Specifications Motor Protection: In H2O Auto Restart/Polarity Protection Insulation Resistance: 10M Ω or over with a DC500V Megger Static Pressure -10°C ~ +60°C (Operating) -40°C ~ +60°C (Storage) (non-condensing environment) Ps Expected Life 60 .20 50 .16 40 .12 30 .08 20 .04 10 (Pa) N M DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: .24 L 0 Failure Rate: 10% 25°C 70,000 Hours (L00/B00) K J 0 0.1 0.2 0.3 0.4 0.5 3.5 7.0 10.6 14.1 17.6 0.6 (m3/min) CFM 21.1 Air Flow Material Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG26, +Red, -Black .169 4 – (φ4.3 ± 0.2) ROTATION AIR 2.24 (57.0) 1.97 (50.0) (φ 2.4 63 8 .0 ) PLATE .169 4 – (φ4.3 ± 0.2) 1.97 (50.0 ± 0.3) 2.36 (60.0 ± 0.3) NAME Panel Cut-Outs inch Units: (mm) 7.87 (200) min Outline 1.97 (50.0 ± 0.3) 2.36 (60.0 ± 0.3) .59 (15 +0.5) 1.97 (50.0) 2.24 (57.0) Rib Type Only INLET SIDE / OUTLET SIDE Specifications MODEL Rated LEGACY P/N Voltage Operating Current Input Speed Max. Max. Static Voltage Power Air Flow Pressure Noise Mass (V) (V) (A)*1 (W)*1 (min-1)*1 06015KA-12J-AA-00 2406KL-04W-B10-L00 12 7.0 ~ 13.8 0.04 0.48 1800 6.7 0.19 .03 8.5 19.0 06015KA-12K-AA-00 2406KL-04W-B20-L00 12 6.0 ~ 13.8 0.07 0.84 3100 11.6 0.33 .09 23.4 25.0 45 06015KA-12L-AA-00 2406KL-04W-B30-L00 12 6.0 ~ 13.8 0.09 1.08 3600 14.1 0.40 .13 31.3 28.0 45 06015KA-12M-AA-00 2406KL-04W-B40-L00 12 6.0 ~ 13.8 0.13 1.56 4100 15.9 0.45 .16 39.7 31.0 45 06015KA-12N-AA-00 2406KL-04W-B50-L00 12 6.0 ~ 13.8 0.16 1.92 4600 18.3 0.52 .20 51.2 34.0 45 06015KA-24J-AA-00 2406KL-05W-B10-L00 24 18.5 ~ 27.6 0.04 0.96 1800 6.7 0.19 .03 8.5 19.0 45 06015KA-24K-AA-00 2406KL-05W-B20-L00 24 12.0 ~ 27.6 0.06 1.44 3100 11.6 0.33 .09 23.4 25.0 45 06015KA-24L-AA-00 2406KL-05W-B30-L00 24 12.0 ~ 27.6 0.06 1.44 3600 14.1 0.40 .13 31.3 28.0 45 06015KA-24M-AA-00 2406KL-05W-B40-L00 24 10.0 ~ 27.6 0.07 1.68 4100 15.9 0.45 .16 39.7 31.0 45 06015KA-24N-AA-00 2406KL-05W-B50-L00 24 10.0 ~ 27.6 0.10 2.40 4600 18.3 0.52 .20 51.2 34.0 45 Rotation: Clockwise Airflow Outlet: Air Out Over Struts CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 *1: Average Values in Free Air Note: Locked Rotor/Tach Available (g) 45
2406KL-04W-B50-L00 价格&库存
很抱歉,暂时无法提供与“2406KL-04W-B50-L00”相匹配的价格&库存,您可以联系我们找货
