1604KL-04W-B50-B00
1604KL-04W-B50-B00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 40X10MM 12VDC WIRE
1604KL-04W-B50-B00 数据手册
04010KA (40 X 10L) Legacy Part No. 1604KL NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: Auto Restart/Polarity Protection Insulation Resistance: -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Expected Life Failure Rate: 10% 25°C 60,000 Hours Material Outline Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL1061, AWG26, +Red, -Black ROTATION .10 (2.7) .09 (2.3) 8 – R3.0 .138 4 – (φ3.5) 7.87 (200) min DC Axial Fans 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: AIR NAME PLATE (3 1.5 9. 4 0) 1.52 (38.6) 1.26 (32.0) .138 4– (φ3.5) 1.57 (40.0 0.3) inch Units: (mm) 1.26 (32.0 0.2) Panel Cut-Outs 1.26 (32.0 0.2) .39 (10.0 0.5) 1.26 (32.0) 1.52 (38.6) 1.57 (40.0 0.3) Rib Type Only INLET SIDE / OUTLET SIDE Specifications Rated MODEL LEGACY P/N Voltage Operating Current Voltage Input Speed Power (V) (V) (A)*1 (W)*1 (min-1)*1 Max. Static Pressure CFM*1 (m3/min)*1 in H2O Noise Mass (Pa)*1 (dB)*1 (g) 1604KL-01W-B30-B00 5 4.5 ~ 5.5 0.075 0.375 4500 4.2 0.12 .096 24.0 22.0 15 04010KA-05M-AA-00 1604KL-01W-B40-B00 5 4.5 ~ 5.5 0.120 0.600 5500 5.3 0.15 .136 34.0 25.0 15 1604KL-01W-B50-B00 5 4.5 ~ 5.5 0.155 0.775 6500 6.0 0.17 .184 46.0 29.0 15 04010KA-12L-AA-00 1604KL-04W-B30-B00 12 10.2 ~ 13.8 0.062 0.744 4500 4.2 0.12 .096 24.0 22.0 15 04010KA-12M-AA-00 1604KL-04W-B40-B00 12 10.2 ~ 13.8 0.073 0.876 5500 5.3 0.15 .136 34.0 25.0 15 1604KL-04W-B50-B00 12 10.2 ~ 13.8 0.073 0.876 6500 6.0 0.17 .184 46.0 29.0 15 04010KA-05L-AA-00 04010KA-05N-AA-00 04010KA-12N-AA-00 2 Max. Air Flow Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air Note: Locked Rotor/Tach Available
1604KL-04W-B50-B00 价格&库存
很抱歉,暂时无法提供与“1604KL-04W-B50-B00”相匹配的价格&库存,您可以联系我们找货
