3108NL-04W-B10-P00
3108NL-04W-B10-P00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 80X20MM 12VDC WIRE
3108NL-04W-B10-P00 数据手册
3108NL (80 X 20L) NMBTC.COM / 248.919.2250 For New Designs we Recommend 08020SA (Pa) In H2O .28 70 Auto Restart/Polarity Protection 10M Ω or over with a DC500V Megger .24 60 .20 50 .16 40 .12 30 Ps .08 20 .04 10 Static Pressure AC 700V 1s -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) B50 B40 B30 B20 B10 0 inch Units: (mm) 0.2 0.4 0.6 7 14 21 0.8 1.0 1.2 1.4 35 42 49 (m3/min) CFM NAME PLATE 2.81 (71.5 ±0.3) 3.15 (80.0 ±0.3) .78 (20.0 ±0.5) .169 4 – (φ4.3) .169 4 – (φ4.3) 30 ) 3. 4.0 8 (φ 46 ) 3. 8.0 8 (φ 2.99 (76.0) 2.81 (71.5) 2.99 (76.0) 2.81 (71.5) AIR 11.8 (300) min ROTATION 2.81 (71.5 ±0.3) 3.15 (80.0 ±0.3) .169 4 – (φ4.3) 28 Air Flow 2.81 (71.5) 2.99 (76.0) 2.81 (71.5) 2.99 (76.0) INLET SIDE OUTLET SIDE Casing : Plastic (Black) 94V-0 Impeller : Plastic (Black) 94V-0 Bearing : Ball Bearing Lead Wire: UL1007, AWG24, +Red, -Black Rated Operating Voltage Voltage (V) (V) (A)*1 (W)*1 (min-1)*1 3108NL-04W-B10- Product No. X00 12 6.0 ~ 13.8 0.09 1.08 2350 26.5 0.75 3108NL-04W-B20- X00 12 6.0 ~ 13.8 0.11 1.32 2600 29.6 0.84 3108NL-04W-B30- X00 12 6.0 ~ 13.8 0.14 1.68 2950 34.6 3108NL-04W-B40- X00 12 6.0 ~ 13.8 0.20 2.40 3350 40.6 3108NL-04W-B50- X00 12 6.0 ~ 13.8 0.28 3.36 3750 3108NL-05W-B10- X00 24 15.0 ~ 27.6 0.05 1.30 2350 3108NL-05W-B20- X00 24 15.0 ~ 27.6 0.06 1.44 2600 29.6 0.84 .10 26.0 29.0 85 3108NL-05W-B30- X00 24 15.0 ~ 27.6 0.07 1.68 2950 34.6 0.98 .13 33.5 32.5 85 MODEL Current Input Speed Power Max. Max. Static Air Flow Pressure Noise Mass (Pa)*1 (dB)*1 (g) .08 21.0 26.0 85 .10 26.0 29.0 85 0.98 .13 33.5 32.5 85 1.15 .17 43.7 38.5 85 44.0 1.25 .20 50.1 42.0 85 26.5 0.75 .08 21.0 26.0 85 CFM*1 (m3/min)*1 in H2O 3108NL-05W-B40- X00 24 15.0 ~ 27.6 0.11 2.64 3350 40.6 1.15 .17 43.7 38.5 85 3108NL-05W-B50- X00 24 15.0 ~ 27.6 0.15 3.60 3750 44.0 1.25 .20 50.1 42.0 85 Rotation: Counterclockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air
3108NL-04W-B10-P00
1. 物料型号:3108NL-04W-B10-, 3108NL-04W-B20-, 3108NL-04W-B30-, 3108NL-04W-B40-, 3108NL-04W-B50-, 3108NL-05W-B10-, 3108NL-05W-B20-, 3108NL-05W-B30-, 3108NL-05W-B40-, 3108NL-05W-B50-。
2. 器件简介:文档推荐使用08020SA型号的DC轴流风扇,具有自动重启和极性保护的电机保护功能。
3. 引脚分配:文档中没有提供引脚分配信息。
4. 参数特性: - 允许环境温度范围:操作时-10°C至+70°C,存储时-40°C至+70°C(非凝结环境)。 - 材料:外壳和叶轮为黑色塑料94V-0,轴承为球轴承,引线为UL1007,AWG24,红色为正,黑色为负。
5. 功能详解:风扇的转速、最大空气流量、最大静压和噪音水平等详细规格参数。
6. 应用信息:文档中没有提供具体的应用信息
7. 封装信息:提供了风扇的外形尺寸和面板切割尺寸。
3108NL-04W-B10-P00 价格&库存
很抱歉,暂时无法提供与“3108NL-04W-B10-P00”相匹配的价格&库存,您可以联系我们找货
