1608VL-05W-B40-B00
1608VL-05W-B40-B00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 40X20MM 24VDC WIRE
1608VL-05W-B40-B00 数据手册
04020VA (40 X 20L) Legacy Part No. 1608VL NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: P-Q Curve In H2O Insulation Resistance: 10M Ω or over with a DC500V Megger Static Pressure 0.30 -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Expected Life Ps 18000 80 16000 70 14000 60 12000 50 0.20 10000 P N 40 8000 M 30 0.10 Failure Rate: 10% 60°C 20000 90 6000 P N 20 4000 M 2000 10 40,000 Hours 0 DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: Speed Curve (Pa) 100 0.40 Speed Auto Restart/Polarity Protection 0 0.0 0.04 0.08 0.12 0.16 0.20 0.24 0 1.4 2.8 4.2 5.6 7.0 0.28 0.32 0.36 0.40 (m3/min) 9.8 11.2 12.6 14.0 CFM 8.4 Air Flow Material Outline Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG26, +Red, -Black 1.57 (40.0± 0.3) 1 (φ .56 39 .8 ) NAME PLATE AIR LOT NO. 56 ) 1. 9.8 3 (φ 1 (φ .56 39 .8 ) .137 (4 – φ3.5) 1.50 (38.0) 1.26 (32.0) 1.50 (38.0) 1.26 (32.0) 1 (φ .56 39 .8 ) .137 (4 – φ3.5) 1.26 (32.0± 0.2) 0.137 (4−φ3.5± 0.2) Panel Cut-Outs inch Units: (mm) 7.87 min (200) ROTATION .157 (4.0) 1.26 (32.0± 0.2) 1.57 (40.1± 0.3) 1.26 (32.0) 1.50 (38.0) 1.26 (32.0) 1.50 (38.0) INLET SIDE OUTLET SIDE 0.78 (20.0± 0.5) .157 (4.0) Specifications Rated MODEL LEGACY P/N Voltage Operating Current Voltage Input Speed Max. Power Max. Static Air Flow (V) (V) (A)*1 (W)*1 (min-1)*1 Noise Mass Pressure CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 1608VL-04W-B40-B00 12 7.0 ~ 13.2 0.08 1.02 7500 8.8 0.25 .24 58.8 29.0 40 04020VA-12N-AA-00 1608VL-04W-B50-B00 12 7.0 ~ 13.2 0.11 1.32 8500 10.2 0.29 .31 76.6 31.4 40 04020VA-12P-AA-00 1608VL-04W-B60-B00 12 7.0 ~ 13.2 0.13 1.56 9500 11.3 0.32 .40 99.3 34.6 40 04020VA-12Q-AA-00 1608VL-04W-B70-B00 12 4.0 ~ 12.6 0.20 2.40 10500 12.7 0.36 .50 125.0 37.7 40 04020VA-24M-AA-00 1608VL-05W-B40-B00 24 14.0 ~ 26.4 0.05 1.20 7500 8.8 0.25 .24 58.8 29.0 40 04020VA-24N-AA-00 1608VL-05W-B50-B00 24 14.0 ~ 26.4 0.07 1.68 8500 10.2 0.29 .31 76.6 31.4 40 04020VA-24P-AA-00 1608VL-05W-B60-B00 24 14.0 ~ 26.4 0.10 2.40 9500 11.3 0.32 .40 99.3 34.6 40 04020VA-12M-AA-00 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available
1608VL-05W-B40-B00 价格&库存
很抱歉,暂时无法提供与“1608VL-05W-B40-B00”相匹配的价格&库存,您可以联系我们找货
