04020VA (40 X 20L)
Legacy Part No. 1608VL
NMBTC.COM / 248.919.2250
Characteristic Curves
General Specifications
Motor Protection:
P-Q Curve
In H2O
Insulation Resistance:
10M Ω or over with a DC500V Megger
Static Pressure
0.30
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Expected Life
Ps
18000
80
16000
70
14000
60
12000
50
0.20
10000
P
N
40
8000
M
30
0.10
Failure Rate: 10%
60°C
20000
90
6000
P
N
M
2000
10
40,000 Hours
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
Speed Curve
(Pa)
100
0.40
Speed
Auto Restart/Polarity Protection
0.04
0.08
0.12
0.16
0.20 0.24
2.8
4.2
5.6
7.0
0.28
0.32
0.36
0.40
(m3/min)
9.8
11.2
12.6
14.0
CFM
8.4
Air Flow
Material
Outline
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL1007, AWG26, +Red, -Black
1.57
(40.0± 0.3)
1
(φ .56
39
.8
NAME
PLATE
AIR
LOT NO.
56 )
1. 9.8
3
(φ
1
(φ .56
39
.8
.137
(4 – φ3.5)
1.50
(38.0)
1.26
(32.0)
1.50
(38.0)
1.26
(32.0)
1
(φ .56
39
.8
.137
(4 – φ3.5)
1.26
(32.0± 0.2)
0.137
(4−φ3.5± 0.2)
Panel Cut-Outs
inch
Units: (mm)
7.87
min (200)
ROTATION
.157
(4.0)
1.26
(32.0± 0.2)
1.57
(40.1± 0.3)
1.26
(32.0)
1.50
(38.0)
1.26
(32.0)
1.50
(38.0)
INLET SIDE
OUTLET SIDE
0.78
(20.0± 0.5)
.157
(4.0)
Specifications
Rated
MODEL
LEGACY P/N
Voltage
Operating Current
Voltage
Input
Speed
Max.
Power
Max. Static
Air Flow
(V) (V) (A)*1 (W)*1 (min-1)*1
Noise
Mass
Pressure
CFM*1 (m3/min)*1 in H2O
(Pa)*1 (dB)*1
(g)
1608VL-04W-B40-B00
12
7.0 ~ 13.2
0.08
1.02
7500
8.8
0.25
.24
58.8
29.0
40
04020VA-12N-AA-00 1608VL-04W-B50-B00
12
7.0 ~ 13.2
0.11
1.32
8500
10.2
0.29
.31
76.6
31.4
40
04020VA-12P-AA-00
1608VL-04W-B60-B00
12
7.0 ~ 13.2
0.13
1.56
9500
11.3
0.32
.40
99.3
34.6
40
04020VA-12Q-AA-00
1608VL-04W-B70-B00
12
4.0 ~ 12.6
0.20
2.40
10500
12.7
0.36
.50
125.0
37.7
40
04020VA-24M-AA-00
1608VL-05W-B40-B00
24
14.0 ~ 26.4
0.05
1.20
7500
8.8
0.25
.24
58.8
29.0
40
04020VA-24N-AA-00
1608VL-05W-B50-B00
24
14.0 ~ 26.4
0.07
1.68
8500
10.2
0.29
.31
76.6
31.4
40
04020VA-24P-AA-00
1608VL-05W-B60-B00
24
14.0 ~ 26.4
0.10
2.40
9500
11.3
0.32
.40
99.3
34.6
40
04020VA-12M-AA-00
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
很抱歉,暂时无法提供与“1608VL-05W-B50-B00”相匹配的价格&库存,您可以联系我们找货
