3610KL-05W-B40-D00
3610KL-05W-B40-D00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 92X25MM 24VDC WIRE
3610KL-05W-B40-D00 数据手册
3610KL (92 X 25L) NMBTC.COM / 248.919.2250 For New Designs we Recommend 09225SA In H2O (Pa) 70 .28 Auto Restart/Polarity Protection 10M Ω or over with a DC500V Megger .24 60 .20 50 .16 40 .12 30 .08 20 .04 10 Static Pressure B60 Class: -10°C ~ +50°C (Operating) B10~B50 Class: -10°C ~ +70°C (Operating) All Class: -40°C ~ +70°C (Storage) (non-condensing environment) Ps 0.3 0.6 0.9 1.2 10 21 32 42 1.8 (m3/min) 2.1 64 74 1.5 CFM 53 Air Flow .169 4 – (�4.3 ± 0.2) 20 ) 4. 6.8 10 (� 3.52 (89.4) 3.25 (82.5) 19 ) 4. 06.4 1 (� 3.52 (89.4) 3.25 (82.5) 11.8 (300) min .169 4 – (�4.3 ± 0.2) 3.22 (82.5 ± 0.25) 3.62 (92.0 ± 0.5) .169 4 – (�4.3 ± 0.2) NAME PLATE B10 0 ROTATION AIR B30 B20 100,000 Hours (B00, E00) 70,000 Hours (G00,D00) 60,000 Hours (C00, F00) inch Units: (mm) B50 B40 AC 700V 1s 25°C 25°C 25°C B60 3.25 (82.5) 3.52 (89.4) 3.25 (82.5) 3.52 (89.4) INLET SIDE OUTLET SIDE Casing : Plastic (Black) 94V-0 Impeller : Plastic (Black) 94V-0 Bearing : Ball Bearing Lead Wire: UL1007, AWG24, +Red, -Black .98 (25.0 ± 0.2) 3.22 (82.5 ± 0.25) 3.62 (92.0 ± 0.5) Rated Operating MODEL V Voltag e V Voltag e (V) (V) (A)*1 3610KL-04W-B10- Product No. X00 12 6.0 ~ 13.8 0.073 0.876 1750 26.5 0.75 .06 14.2 25.0 95 3610KL-04W-B20- X00 12 6.0 ~ 13.8 0.110 1.320 2100 33.5 0.95 .08 20.1 29.5 95 3610KL-04W-B30- X00 12 6.0 ~ 13.8 0.160 1.920 2450 40.6 1.15 .11 27.0 34.0 95 3610KL-04W-B40- X00 12 6.0 ~ 13.8 0.220 2.640 2850 47.6 1.35 .15 37.2 37.5 95 3610KL-04W-B50- X00 12 6.0 ~ 13.0 0.315 3.780 3200 54.7 1.55 .19 48.0 41.0 95 3610KL-04W-B60- X00 12 6.0 ~ 12.6 0.430 5.160 3600 61.8 1.75 .23 57.2 44.5 95 3610KL-05W-B10- X00 24 10.0 ~ 27.6 0.05 1.20 1750 26.5 0.75 .06 14.2 25.0 95 3610KL-05W-B20- X00 24 10.0 ~ 27.6 0.06 1.44 2100 33.5 0.95 .08 20.1 29.5 95 3610KL-05W-B30- X00 24 10.0 ~ 27.6 0.09 2.16 2450 40.6 1.15 .11 27.0 34.0 95 3610KL-05W-B40- X00 24 10.0 ~ 27.6 0.12 2.88 2850 47.6 1.35 .15 37.2 37.5 95 3610KL-05W-B50- X00 24 10.0 ~ 25.0 0.16 3.84 3200 54.7 1.55 .19 48.0 41.0 95 3610KL-05W-B60- X00 24 10.0 ~ 25.0 0.20 4.80 3600 61.8 1.75 .23 57.2 44.5 95 Rotation: Clockwise Current Input Speed Power (W)*1 (min-1)*1 Airflow Outlet: Air Out Over Struts Max. Max. Static Air Flow Pressure CFM*1 (m3/min)*1 in H2O (Pa)*1 Noise Mass (dB)*1 (g) *1: Average A Values in Free Air V
3610KL-05W-B40-D00
物料型号:3610KL (92 x 25L)
器件简介:这是NMB品牌的一款DC轴流风扇,适用于新设计的产品,推荐使用09225SA型号。
引脚分配:文档中未提供引脚分配信息。
参数特性: - 电机保护:10MΩ或以上,使用DC500V Megger测试。 - 允许的环境温度范围:B60类为-10°C至+50°C(运行),B10~B50类为-10°C至+70°C(运行);所有类别的存储温度范围为-40°C至+70°C(非凝结环境)。 - 预期寿命:在25°C下,B00和E00型号的故障率为10%,寿命为100,000小时;G00和D00型号为70,000小时;C00和F00型号为60,000小时。
功能详解:风扇具有自动重启/极性保护功能。
应用信息:文档中未提供具体的应用信息
封装信息:外壳材料为黑色塑料(94V-0),叶轮为黑色塑料(94V-0),轴承为球轴承,引线为UL1007,AWG24,红色为正,黑色为负。
3610KL-05W-B40-D00 价格&库存
很抱歉,暂时无法提供与“3610KL-05W-B40-D00”相匹配的价格&库存,您可以联系我们找货
