3610VL-05W-B70-E00
3610VL-05W-B70-E00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 92X25MM 24VDC WIRE
3610VL-05W-B70-E00 数据手册
09225VA (92 X 25L) Legacy Part No. 3610VL NMBTC.COM / 818.341.3355 Characteristic Curves General Specifications Motor Protection: Auto Restart/Polarity Protection .80 Insulation Resistance: P-Q Curve (Pa) In H2O Speed Curve 200 6000 Q 10M Ω or over with a DC500V Megger P -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) N 150 4500 M L .40 100 .20 50 K 3000 Speed Static Pressure DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: .60 Ps Expected Life Failure Rate: 10% 60°C 40,000 Hours (AA/EA) 0 1500 K 0.0 1.0 0.0 35 L M N P Q 0 2.0 3.0 70 105 (m3/min) CFM Air Flow Material Outline Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL3385, AWG26, +Red, -Black NAME PLATE .169 (4 – φ4.3) 4 (φ .13 10 5) 3.25 (82.5) 3.62 (89.0) 3.25 (82.5± 0.3) 3.62 (92.0 ± 0.5) .98 (25.0± 0.5) 3.25 (82.5) 3.62 (89.0) 3.25 (82.5) 3.62 (89.0) 3 (φ .70 94 ) .169 (4 – φ4.3) 3.62 (92.0± 0.5) AIR 3.25 (82.5± 0.3) 0.169 (4−φ4.3± 0.2) Panel Cut-Outs inch Units: (mm) 11.8 min (300) ROTATION LOT NO. 3.25 (82.5) 3.62 (89.0) INLET SIDE OUTLET SIDE Specifications Rated Voltage MODEL Operating Current Voltage Input Speed Power Max. Max. Static Air Flow Noise Mass Pressure (V) (V) (A)*1 (W)*1 (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 09225VA-12K-AA-00 3610VL-04W-B20-B00 12 7.0 ~ 13.8 0.18 2.16 3200 54.0 1.53 .20 50 35.5 135 09225VA-12L-AA-00 3610VL-04W-B30-B00 12 7.0 ~ 13.8 0.24 2.88 3600 61.1 1.73 .26 65 38.5 135 09225VA-12M-AA-00 3610VL-04W-B40-B00 12 7.0 ~ 13.8 0.30 3.60 4000 68.1 1.93 .32 80 42.0 135 09225VA-12N-AA-00 3610VL-04W-B50-B00 12 7.0 ~ 13.8 0.40 4.80 4500 77.0 2.18 .39 98 45.0 135 09225VA-12P-AA-00 3610VL-04W-B60-B00 12 7.0 ~ 13.8 0.52 6.24 5000 85.8 2.43 .48 120 48.0 135 09225VA-12Q-AA-00 3610VL-04W-B70-B00 12 7.0 ~ 13.8 0.72 8.64 5600 96.4 2.73 .60 150 51.0 135 09225VA-24K-AA-00 3610VL-05W-B20-B00 24 14.0 ~ 27.6 0.11 2.64 3200 54.0 1.53 .20 50 35.5 135 3610VL-05W-B30-B00 24 14.0 ~ 27.6 0.14 3.36 3600 61.1 1.73 .26 65 38.5 135 09225VA-24M-AA-00 3610VL-05W-B40-B00 24 14.0 ~ 27.6 0.17 4.08 4000 68.1 1.93 .32 80 42.0 135 09225VA-24N-AA-00 3610VL-05W-B50-B00 24 14.0 ~ 27.6 0.22 5.28 4500 77.0 2.18 .39 98 45.0 135 09225VA-24P-AA-00 3610VL-05W-B60-B00 24 14.0 ~ 27.6 0.28 6.72 5000 85.8 2.43 .48 120 48.0 135 09225VA-24Q-AA-00 3610VL-05W-B70-B00 24 14.0 ~ 27.6 0.38 9.12 5600 96.4 2.73 .60 150 51.0 135 09225VA-24L-AA-00 13 LEGACY P/N Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available
3610VL-05W-B70-E00
1. 物料型号:文档列出了不同型号的风扇,例如09225VA-12K-AA-00、09225VA-12L-AA-00等,每个型号都有对应的Legacy Part Number。
2. 器件简介:这些风扇具备自动重启和极性保护功能,绝缘电阻至少为10MΩ,耐电压测试为AC 700V 1秒。
3. 引脚分配:文档中没有明确提供引脚分配信息。
4. 参数特性:包括额定电压、工作电压、电流、输入功率、转速、最大空气流量、最大静压、噪音水平、质量和旋转方向。
5. 功能详解:风扇设计用于在60°C下运行40,000小时,具有预期寿命和故障率。
6. 应用信息:文档中没有提供具体的应用场景,但通常这类风扇用于电子设备散热。
7. 封装信息:包括外壳、叶轮的材料和颜色,轴承类型,以及引线规格。
8. 其他特性:如面板切割尺寸、空气流向和特性曲线等。
3610VL-05W-B70-E00 价格&库存
很抱歉,暂时无法提供与“3610VL-05W-B70-E00”相匹配的价格&库存,您可以联系我们找货
