1622FT-04W-B86-E00
1622FT-04W-B86-E00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 40X56MM 12VDC WIRE
1622FT-04W-B86-E00 数据手册
1622FT (40 X 56L) NMBTC.COM / 818.341.3355 PATENT PENDING Characteristic Curves General Specifications Motor Protection: (Pa) In H2O P-Q Curve 4.00 1000 25000 3.20 800 20000 Static Pressure 2.40 600 15000 Ps 1.60 400 10000 .80 200 5000 Insulation Resistance: min 10M Ω by DC500V Megger Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: -10°C ~ +60°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Expected Life 0 Failure Rate: 10% 40°C 70,000 Hours 0 0.0 0.2 0.4 0.6 0.8 1.0 0.0 7 14 21 28 35 Air Flow Panel Cut-outs PATENT PENDING .137 (4 – F3.5) 1.56 (39.6) 1.26 (32.0) 72 6) 1. 43. ( 1.51 (38.4) 1.26 (32.0) 11.82 min (300) .137 (4 – F3.5) ROTATION 0.197 (5.0)( 2.2 (56.0 ± 0.5) 0 (R .09 2. 5) 1.57 (40.0 ± 0.5) 1.26 (32.0 ± 0.3) 1.26 (32.0) 1.56 (39.6) Rib Type 1.26 (32.0) 1.51 (38.4) INLET SIDE OUTLET SIDE Material 1.26 (32± 0.3) 1.57 (40.0 ± 0.5) 0.197 (5.0) 62 ) 1. 1.2 4 (F .137 (4 – F3.5) LOT NO. DC Axial Fans - TurboFans inch Units: (mm) NAME PLATE (m3/min) CFM Outline AIR Speed Speed Curve Auto Restart/Polarity Protection Casing : Plastic (Black) 94V-0 Impeller : Plastic (Black) 94V-0 Bearing : Ball Bearing Lead Wire : UL10368, AWG24, +Red, -Black Tach Sig. : White PWM Control : Brown Flange Type Reference PWM Duty vs Speed Curve Through Hole at Vin=12VDC, Ta=25˚C 30000 PWM Control Voltage 25000 One Side Flange Type Speed [min -1] One Side Rib Type Vst = 0V ~ 0.5V Stop (On Duty 0%) Vst = 3.0V ~ 5.0V Full Speed (On Duty 100%) Vst = Open Full Speed Through Hole (At Ta = 25°C, rated voltage 12VDC) 20000 max 15000 min 10000 5000 0 0 Rated Voltage Operating Voltage Current Input Power Speed Product No. (V) (V) (A)*1 (W)*1 (min-1)*1 EXX 12 10.2 ~ 13.2 1.05 12.60 23,000 MODEL 1622FT-04W-B86- Rotation: Clockwise Airflow Outlet: Air Out Over Struts 20 40 60 80 100 PWM Duty 0% Duty Stop Max. Air Flow Noise Mass CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 30.0 60.0 68 0.85 *1: Average Values in Free Air Max. Static Pressure 3.54 885.0 0.0
1622FT-04W-B86-E00 价格&库存
很抱歉,暂时无法提供与“1622FT-04W-B86-E00”相匹配的价格&库存,您可以联系我们找货
