09225SA-12L-EA-00
09225SA-12L-EA-00
    NMBTECHNOLOGIESCORPORATION
    FAN AXIAL 92X25MM 12VDC WIRE
09225SA-12L-EA-00 数据手册
09225SA (92 X 25L) Legacy Part No. 3610SB NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: P-Q Curve In H2O (Pa) Insulation Resistance: 10M Ω or over with a DC500V Megger Static Pressure -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Ps Expected Life 60 6000 0.20 50 5000 0.16 40 4000 P 0.12 N 30 0.08 20 K N 40,000 Hours (AA/EA) 3000 M L 0.04 10 0.00 0 2000 P M L K Failure Rate: 10% 60°C DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: Speed Curve 0.24 Speed Auto Restart/Polarity Protection 1000 0 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0.0 7.0 14.0 21.0 28.0 35.0 42.0 49.0 56.0 63.0 (m3/min) CFM Air Flow Material Outline 11.8 min (300) Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL3385, AWG26, +Red, -Black ROTATION .169 (4−φ4.3± 0.2) Panel Cut-Outs .169 (4 – φ4.3) 3.25 (82.5± 0.3) 3.62 (92.0± 0.5) 09 0) 4. 04. 1 (φ 3.25 (82.5) 3.53 (89.6) 94 0) 3. 00. 1 ( .169 (4 – φ4.3) 3.25 (82.5± 0.3) 3.62 (92.0 ± 0.5) 3.25 (82.5) 3.53 (89.6) 3.25 (82.5) 3.53 (89.6) INLET SIDE 0.98 (25.0± 0.5) OUTLET SIDE Rated LEGACY P/N Voltage Operating Current Voltage ROTATION 11.8 min (300) Specifications MODEL AIR NAME PLATE 3.25 (82.5) 3.53 (89.6) inch Units: (mm) Input Speed Max. .169 ± 0.2) (4−φ4.3 Air Flow Power Max. Static Noise Mass Pressure (V) (V) (A)*1 (W)*1 (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 09225SA-12K-AA-D0 3610SB-04W-B20-B00 12 6 ~ 13.8 2050 33.5 3610SB-04W-B30-B00 12 6 ~ 13.8 2400 39.9 09225SA-12M-AA-D0 3610SB-04W-B40-B00 12 2750 45.2 09225SA-12N-AA-D0 3610SB-04W-B50-B00 09225SA-12P-AA-D0 1.20 6 ~ 13.8 0.14 1.68 12 6 ~ 13.8 0.16 1.92 3100 3610SB-04W-B60-B00 12 6 ~ 13.2 0.23 2.76 09225SA-24K-AA-D0 3610SB-05W-B20-B00 24 12 ~ 27.6 0.96 09225SA-24L-AA-D0 3610SB-05W-B30-B00 24 12 ~ 27.6 0.04 .157 09225SA-24M-AA-D0 3610SB-05W-B40-B00 24 12 ~ 27.6 .157 1.20 (4.0) 0.98 0.07 ) (25.0± 0.51.68 09225SA-24N-AA-D0 3610SB-05W-B50-B00 24 12 ~ 26.4 0.08 1.92 09225SA-24P-AA-D0 3610SB-05W-B60-B00 24 10 ~ 27.6 0.12 2.88 Rotation: Clockwise Airflow Outlet: Air Out Over Struts (4.0) 0.05 0.09 21.5 22.0 95 1.13 0.12 29.0 25.0 95 1.28 0.15 36.2 29.0 95 51.2 1.45 0.18 45.0 32.0 95 3550 62.5 1.77 0.24 61.0 39.0 95 2050 33.5 0.95 0.09 21.5 22.0 95 2400 39.9 0.12 29.0 25.0 95 2750 45.2 3100 51.2 3550 62.5 3.25 (82.5± 0.3) 0.84 0.10 AIR 3.62 (92.0± 0.5) 0.07 09225SA-12L-AA-D0 *1: Average Values in Free Air 0.95 NAME PLATE 3.25 ± 0.3) 1.13 (82.5 3.62 1.28 (92.0 ± 0.5) 0.15 36.2 29.0 95 1.45 0.18 45.0 32.0 95 1.77 0.24 61.0 39.0 95 Note: PWM/Locked Rotor/Tach Available
09225SA-12L-EA-00 价格&库存
很抱歉,暂时无法提供与“09225SA-12L-EA-00”相匹配的价格&库存,您可以联系我们找货
