09225SA (92 X 25L)
Legacy Part No. 3610SB
NMBTC.COM / 248.919.2250
Characteristic Curves
General Specifications
Motor Protection:
P-Q Curve
In H2O (Pa)
Insulation Resistance:
10M Ω or over with a DC500V Megger
Static Pressure
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Ps
Expected Life
60
6000
0.20
50
5000
0.16
40
4000
P
0.12
N
30
0.08
K
N
40,000 Hours (AA/EA)
3000
M
L
0.04
10
0.00
P
M
L
K
Failure Rate: 10%
60°C
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
Speed Curve
0.24
Speed
Auto Restart/Polarity Protection
1000
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
0.0
7.0
14.0
21.0
28.0
35.0
42.0
49.0
56.0
63.0
(m3/min)
CFM
Air Flow
Material
Outline
11.8
min (300)
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL3385, AWG26, +Red, -Black
ROTATION
.169
(4−φ4.3± 0.2)
Panel Cut-Outs
.169
(4 – φ4.3)
3.25
(82.5± 0.3)
3.62
(92.0± 0.5)
09 0)
4. 04.
1
(φ
3.25
(82.5)
3.53
(89.6)
94 0)
3. 00.
1
.169
(4 – φ4.3)
3.25
(82.5± 0.3)
3.62
(92.0 ± 0.5)
3.25
(82.5)
3.53
(89.6)
3.25
(82.5)
3.53
(89.6)
INLET SIDE
0.98
(25.0± 0.5)
OUTLET SIDE
Rated
LEGACY P/N
Voltage
Operating Current
Voltage
ROTATION
11.8
min (300)
Specifications
MODEL
AIR
NAME
PLATE
3.25
(82.5)
3.53
(89.6)
inch
Units: (mm)
Input
Speed
Max. .169
± 0.2)
(4−φ4.3
Air Flow
Power
Max. Static
Noise
Mass
Pressure
(V) (V) (A)*1 (W)*1 (min-1)*1
CFM*1 (m3/min)*1 in H2O
(Pa)*1 (dB)*1
(g)
09225SA-12K-AA-D0
3610SB-04W-B20-B00
12
6 ~ 13.8
2050
33.5
3610SB-04W-B30-B00
12
6 ~ 13.8
2400
39.9
09225SA-12M-AA-D0 3610SB-04W-B40-B00
12
2750
45.2
09225SA-12N-AA-D0
3610SB-04W-B50-B00
09225SA-12P-AA-D0
1.20
6 ~ 13.8
0.14
1.68
12
6 ~ 13.8
0.16
1.92
3100
3610SB-04W-B60-B00
12
6 ~ 13.2
0.23
2.76
09225SA-24K-AA-D0
3610SB-05W-B20-B00
24
12 ~ 27.6
0.96
09225SA-24L-AA-D0
3610SB-05W-B30-B00
24
12 ~ 27.6
0.04
.157
09225SA-24M-AA-D0 3610SB-05W-B40-B00
24
12 ~ 27.6
.157
1.20
(4.0)
0.98
0.07
(25.0± 0.51.68
09225SA-24N-AA-D0
3610SB-05W-B50-B00
24
12 ~ 26.4
0.08
1.92
09225SA-24P-AA-D0
3610SB-05W-B60-B00
24
10 ~ 27.6
0.12
2.88
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
(4.0)
0.05
0.09
21.5
22.0
95
1.13
0.12
29.0
25.0
95
1.28
0.15
36.2
29.0
95
51.2
1.45
0.18
45.0
32.0
95
3550
62.5
1.77
0.24
61.0
39.0
95
2050
33.5
0.95
0.09
21.5
22.0
95
2400
39.9
0.12
29.0
25.0
95
2750
45.2
3100
51.2
3550
62.5
3.25
(82.5± 0.3)
0.84
0.10
AIR
3.62
(92.0± 0.5)
0.07
09225SA-12L-AA-D0
*1: Average Values in Free Air
0.95
NAME
PLATE
3.25
± 0.3)
1.13
(82.5
3.62
1.28
(92.0 ± 0.5)
0.15
36.2
29.0
95
1.45
0.18
45.0
32.0
95
1.77
0.24
61.0
39.0
95
Note: PWM/Locked Rotor/Tach Available
很抱歉,暂时无法提供与“3610SB-05W-B20-B00”相匹配的价格&库存,您可以联系我们找货
