MA2506H05C-RSR
MA2506H05C-RSR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL25X6MM5VDC
MA2506H05C-RSR 数据手册
0.98 ± 0.01 (25 ±0.3) 4.0 0.24 ± 0.01 (6.1 ±0.2) 0.79 ± 0.01 (20.0 ±0.2) STATIC PRESSURE - MM OF WATER DC AXIAL FANS MA2506 series 0.11 ± 0.01 (Ø2.8 ±0.1) 3.0 L M H 2.0 1.0 0 0.02 0.04 0.06 0.08 AIR FLOW (M3/MIN) (25 x 25 x 6.1 mm) 0.98 x 0.98 x 0.24 inches Construction: UL94V-0 PBT impeller & frame Bearing option: ball bearing or sleeve Connection: AWG 30, UL1007 lead wires Frame: ribbed Protection: thermal 12.11.14 Options: 12.15.14 Rated Operating Current Voltage Voltage V MA2506L tachometer output signal w w w.mechatronic s.com Model No. V mA Speed RPM M³/Min. CFM 50 MA2506M 5 3 - 6.5 60 8,500 0.05 1.65 2.30 MA2506H 5 3 - 6.5 70 10,500 0.06 2.08 3.37 Tel: 425 -2 2 2- 5 9 0 0 1.22 MM 3 - 6.5 Fa x : 425 -2 2 2- 515 5 0.03 Max. Static Pressure (H2 0) 5 E - mail: S ales @ M echatronic s.com 6,500 Air Volume 800-453-4569 1.25 Sound Noise Weight g INCH dbA 0.05 11.0 8 0.09 19.0 8 0.13 25.5 8 Cooling Simplified
MA2506H05C-RSR 价格&库存
很抱歉,暂时无法提供与“MA2506H05C-RSR”相匹配的价格&库存,您可以联系我们找货
