04028DA (40 X 28L)
NMBTC.COM / 818.341.3355
Characteristic Curves
General Specifications
Motor Protection:
P-Q Curve
In H2O (Pa)
Insulation Resistance:
1.8
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
Static Pressure
-10°C ~ +70°C (Operating)
-30°C ~ +70°C (Storage)
(non-condensing environment)
Ps
Expected Life
1.4
500
20000
450
18000
400
16000
350
14000
300
12000
250
1.0
8000
Q class
150
.6
4000
50
.2
0.0
0.1
0.2
0.0
0.3
0.4
3.5
0.6 (m3/min)
0.5
14.1
CFM
21.1
Air Flow
Material
ROTATION
AIR
NAME
PLATE
inch
Units: (mm)
.169
(4 – φ3.5)
1.6
(φ4 1
1.0
1.6
(φ4 1
1.0
.157
(4.0)
1.10
(28.0± 0.5)
Reference PWM Duty Vs. Speed Curve
1.26
(32.0)
1.26
(32.0)
1.51
(38.4)
1.51
(38.4)
INLET SIDE
OUTLET SIDE
R class [04028DA-12R-AU-F0]
20000
18000
16000
14000
Speed (min- 1)
PWM Control Voltage
max
12000
10000
Vst = 0V ~ 0.4V
Stop (On Duty 0%)
Vst = 3.0V ~ 5.0V Full Speed (On Duty 100%)
Vst = Open
(At Ta = 25°C, rated voltage 12VDC, f=25.0kHz)
mi
n
8000
6000
4000
2000
Specifications
LOT NO.
1.26
(32.0± 0.3)
1.57
(40.0 ± 0.5)
.157
(4.0)
0.1
4-R 1
3
1.51
(38.4)
1.26
(32.0)
1.6
(φ4 1
1.0
0.1
4-R 1
3
1.26
(32.0)
1.51
(38.4)
.137
(4 – φ3.5)
1.57
(40.0± 0.0)
0.137
(4−φ3.5± 0.3)
Panel Cut-Outs
1.6
(φ4 1
1.0
7.88
min (200)
Outline
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL10368, AWG 26, +Red, -Black
Tach Sig. : White
PWM Control : Brown
10%
20%
30%
40%
50% 60%
70%
80%
90% 100%
PWM Duty (%)
Rated
Operating
Current
Input
Speed
Max.
Max. Static
Noise
Voltage
Voltage
Power
Air Flow
Pressure
(V)
(V)
(A)*1
04028DA-12Q-AA-F0
12
12
10.8 ~ 13.2
10.8 ~ 13.2
0.18
0.29
2.16
3.48
12000
15000
13.1
16.6
0.37
0.47
0.92
1.37
230.0
340.0
45.0
49.5
53
53
04028DA-12R-AA-F0
12
10.8 ~ 13.2
0.43
5.16
18000
20.1
0.57
1.93
480.0
54.5
53
MODEL
4
6000
P class
100
Failure Rate: 10%
40°C 70,000 Hours
10000
R class
200
1.26
(32.0± 0.3)
DC Axial Fans
10M Ω by DC500V Megger
Speed Curve
N [min -1 ]
Speed
Auto Restart/Polarity Protection
04028DA-12P-AA-F0
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
(W)*1 (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
*1: Average Values in Free Air
Mass
(g)
Note: PWM/Locked Rotor/Tach Available
很抱歉,暂时无法提供与“04028DA-12R-AU-F0”相匹配的价格&库存,您可以联系我们找货
